Ana içeriğe geç
HP OfficeJet 4650 Power Button Replacement
Neye ihtiyacın var
    1. HP OfficeJet 4650 Power Button Replacement, Power Button: adım 1, 3 resimden 1. HP OfficeJet 4650 Power Button Replacement, Power Button: adım 1, 3 resimden 2. HP OfficeJet 4650 Power Button Replacement, Power Button: adım 1, 3 resimden 3.
      • Open the cartridge access door by putting one hand on the grooves of each side and pulling up.
      FixBot'a Sor
      Yorum Ekle
    2. HP OfficeJet 4650 Power Button Replacement: adım 2, 2 resimden 1. HP OfficeJet 4650 Power Button Replacement: adım 2, 2 resimden 2.
      • Using the 2.0 mm hex screwdriver, remove the 14 mm hex screw that binds the front cover to the printer body by turning the screw counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    3. HP OfficeJet 4650 Power Button Replacement: adım 3, 3 resimden 1. HP OfficeJet 4650 Power Button Replacement: adım 3, 3 resimden 2. HP OfficeJet 4650 Power Button Replacement: adım 3, 3 resimden 3.
      • Release the front panel from its internal hooks by applying a little force and sliding the front panel to the right.
      • Push the panel upward to remove it from the printer.
      • There is a connector attached to the back of the panel. Flip the front cover towards you gently and proceed to the next step.
      FixBot'a Sor
      Yorum Ekle
    4. HP OfficeJet 4650 Power Button Replacement: adım 4, 3 resimden 1. HP OfficeJet 4650 Power Button Replacement: adım 4, 3 resimden 2. HP OfficeJet 4650 Power Button Replacement: adım 4, 3 resimden 3.
      • Remove the connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from the circuit board.
      FixBot'a Sor
      Yorum Ekle
    5. HP OfficeJet 4650 Power Button Replacement: adım 5, 3 resimden 1. HP OfficeJet 4650 Power Button Replacement: adım 5, 3 resimden 2. HP OfficeJet 4650 Power Button Replacement: adım 5, 3 resimden 3.
      • Using the Torx T6 hex screwdriver, remove the 7.0mm screw that binds the front cover to the printer body by turning the screw counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    6. HP OfficeJet 4650 Power Button Replacement: adım 6, 3 resimden 1. HP OfficeJet 4650 Power Button Replacement: adım 6, 3 resimden 2. HP OfficeJet 4650 Power Button Replacement: adım 6, 3 resimden 3.
      • Remove the connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from button circuit board.
      FixBot'a Sor
      Yorum Ekle
    7. HP OfficeJet 4650 Power Button Replacement: adım 7, 3 resimden 1. HP OfficeJet 4650 Power Button Replacement: adım 7, 3 resimden 2. HP OfficeJet 4650 Power Button Replacement: adım 7, 3 resimden 3.
      • Pop the button off from the black cover by using your finger tip to bring it up.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephanie Carpintero
1.021 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G6, Livingston Winter 2018 Cal Poly, Team S19-G6, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S19G6
3 Üyeler
30 adet Kılavuz yazıldı
6Kılavuz Yorumları
Does this fix the printer not turning on?
cindim - Yanıt Paylaş
Where can I purchase the replacement Power Button? What is the part number?
Mort Rosenberg - Yanıt Paylaş
Is it possible to bypass the malfunctioning power button, so the printer is on whenever it is plugged in? If so, how?
Ron Sela - Yanıt Paylaş
Jack Farr
Jack Farr - Yanıt Paylaş
Bonjour,
Ou peut on acheter l'écran tactile HP Officejet 4650 ???
Georges N'GUELA - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 44
Her zaman: 4,334
