Ana içeriğe geç
HP Officejet 4630 Fax Feeder Replacement
Neye ihtiyacın var
  1. HP Officejet 4630 Fax Feeder Replacement, Fax Feeder: adım 1, 2 resimden 1. HP Officejet 4630 Fax Feeder Replacement, Fax Feeder: adım 1, 2 resimden 2.
    • Lift the fax feeder cover until it stands on its own.
  2. HP Officejet 4630 Fax Feeder Replacement: adım 2, 3 resimden 1. HP Officejet 4630 Fax Feeder Replacement: adım 2, 3 resimden 2. HP Officejet 4630 Fax Feeder Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to unclasp the hinge that holds the feeder cover.
  3. HP Officejet 4630 Fax Feeder Replacement: adım 3, 2 resimden 1. HP Officejet 4630 Fax Feeder Replacement: adım 3, 2 resimden 2.
    • Lift the green tab to remove the fax feeder from the printer.
  4. HP Officejet 4630 Fax Feeder Replacement: adım 4, 3 resimden 1. HP Officejet 4630 Fax Feeder Replacement: adım 4, 3 resimden 2. HP Officejet 4630 Fax Feeder Replacement: adım 4, 3 resimden 3.
    • Use the plastic opening tool to pry the pivot point apart while lifting the feeder up.
    • There is still a cable holding the part to the rest of the printer.
  5. HP Officejet 4630 Fax Feeder Replacement: adım 5, 2 resimden 1. HP Officejet 4630 Fax Feeder Replacement: adım 5, 2 resimden 2.
    • Use a screwdriver to remove the single 9mm T10 screw.
    • Remove the wire cover and pull the wire away from the printer. The fax feeder head is now free to be separated from the printer.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Isaac Jacobsen
612 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G3, Livingston Winter 2018 Cal Poly, Team S18-G3, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S18G3
4 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
I am so glad i found this site…I was able to unjam a lease that had gotten stuck…..thank you thank you7… times over…Lee
Lee Shankle - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 1,136
