Ana içeriğe geç
HP Officejet 4630 LCD Display Replacement
Neye ihtiyacın var
  1. HP Officejet 4630 LCD Display Replacement, LCD Display: adım 1, 3 resimden 1. HP Officejet 4630 LCD Display Replacement, LCD Display: adım 1, 3 resimden 2. HP Officejet 4630 LCD Display Replacement, LCD Display: adım 1, 3 resimden 3.
    • There is a hidden screw underneath the model sticker on the front panel.
    • Peel the model sticker off the cover.
    • This will expose the T10 screw securing the panel.
  2. HP Officejet 4630 LCD Display Replacement: adım 2, 3 resimden 1. HP Officejet 4630 LCD Display Replacement: adım 2, 3 resimden 2. HP Officejet 4630 LCD Display Replacement: adım 2, 3 resimden 3.
    • Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Loosen the panel cover from the printer body.
    • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
  3. HP Officejet 4630 LCD Display Replacement: adım 3, 3 resimden 1. HP Officejet 4630 LCD Display Replacement: adım 3, 3 resimden 2. HP Officejet 4630 LCD Display Replacement: adım 3, 3 resimden 3.
    • Gently remove the No-Fuss ribbon cable from the front panel.
  4. HP Officejet 4630 LCD Display Replacement: adım 4, 3 resimden 1. HP Officejet 4630 LCD Display Replacement: adım 4, 3 resimden 2. HP Officejet 4630 LCD Display Replacement: adım 4, 3 resimden 3.
    • Remove the seven 8mm screws using the Torx T6 screwdriver.
    • Remove the motherboard from the front-panel housing.
    • The LCD display is on the opposite side.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Justin Engwall
158 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G3, Livingston Winter 2018 Cal Poly, Team S18-G3, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S18G3
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 1,854
