Ana içeriğe geç
HP Officejet 4630 Paper Tray Replacement
Neye ihtiyacın var
    1. HP Officejet 4630 Paper Tray Replacement, Paper Tray: adım 1, 1 resimden 1.
      • Begin by turning your printer upside down.
      • It can be helpful to position an object beneath the printer to keep it level while you work on it.
      FixBot'a Sor
      Yorum Ekle
    2. HP Officejet 4630 Paper Tray Replacement: adım 2, 1 resimden 1.
      • Use the T-10 screwdriver to remove the two 11-mm screws.
      FixBot'a Sor
      Yorum Ekle
    3. HP Officejet 4630 Paper Tray Replacement: adım 3, 1 resimden 1.
      • Pull the paper tray out until it hits the stops on either side of the tray.
      FixBot'a Sor
      Yorum Ekle
    4. HP Officejet 4630 Paper Tray Replacement: adım 4, 3 resimden 1. HP Officejet 4630 Paper Tray Replacement: adım 4, 3 resimden 2. HP Officejet 4630 Paper Tray Replacement: adım 4, 3 resimden 3.
      • Lift up on one side of the black plastic bar with one hand while pulling the paper tray out of the printer with your other hand.
      • The side of the tray should slide away from the printer a little bit.
      FixBot'a Sor
      Yorum Ekle
    5. HP Officejet 4630 Paper Tray Replacement: adım 5, 2 resimden 1. HP Officejet 4630 Paper Tray Replacement: adım 5, 2 resimden 2.
      • Repeat the previous step but for the other side of the tray.
      FixBot'a Sor
      Yorum Ekle
    6. HP Officejet 4630 Paper Tray Replacement: adım 6, 1 resimden 1.
      • The paper tray should now be free to slide away from the printer.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Tyler Allen
513 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G3, Livingston Winter 2018 Cal Poly, Team S18-G3, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S18G3
4 Üyeler
46 adet Kılavuz yazıldı
1Rehber Yorum
merci pour l info!
devaux - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 2,470
