Ana içeriğe geç
HP Officejet 4630 Scanner Head Replacement
Neye ihtiyacın var
  1. HP Officejet 4630 Scanner Head Replacement, LCD Display: adım 1, 3 resimden 1. HP Officejet 4630 Scanner Head Replacement, LCD Display: adım 1, 3 resimden 2. HP Officejet 4630 Scanner Head Replacement, LCD Display: adım 1, 3 resimden 3.
    • There is a hidden screw underneath the model sticker on the front panel.
    • Peel the model sticker off the cover.
    • This will expose the T10 screw securing the panel.
  2. HP Officejet 4630 Scanner Head Replacement: adım 2, 3 resimden 1. HP Officejet 4630 Scanner Head Replacement: adım 2, 3 resimden 2. HP Officejet 4630 Scanner Head Replacement: adım 2, 3 resimden 3.
    • Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Loosen the panel cover from the printer body.
    • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
  3. HP Officejet 4630 Scanner Head Replacement: adım 3, 3 resimden 1. HP Officejet 4630 Scanner Head Replacement: adım 3, 3 resimden 2. HP Officejet 4630 Scanner Head Replacement: adım 3, 3 resimden 3.
    • Gently remove the No-Fuss ribbon cable from the front panel.
  4. HP Officejet 4630 Scanner Head Replacement: adım 4, 3 resimden 1. HP Officejet 4630 Scanner Head Replacement: adım 4, 3 resimden 2. HP Officejet 4630 Scanner Head Replacement: adım 4, 3 resimden 3.
    • Remove the seven 8mm screws using the Torx T6 screwdriver.
    • Remove the motherboard from the front-panel housing.
    • The LCD display is on the opposite side.
  5. HP Officejet 4630 Scanner Head Replacement, Power Supply: adım 5, 3 resimden 1. HP Officejet 4630 Scanner Head Replacement, Power Supply: adım 5, 3 resimden 2. HP Officejet 4630 Scanner Head Replacement, Power Supply: adım 5, 3 resimden 3.
    • Lift the hood of the printer.
  6. HP Officejet 4630 Scanner Head Replacement: adım 6, 3 resimden 1. HP Officejet 4630 Scanner Head Replacement: adım 6, 3 resimden 2. HP Officejet 4630 Scanner Head Replacement: adım 6, 3 resimden 3.
    • Remove the two T10 11mm screws.
  7. HP Officejet 4630 Scanner Head Replacement: adım 7, 3 resimden 1. HP Officejet 4630 Scanner Head Replacement: adım 7, 3 resimden 2. HP Officejet 4630 Scanner Head Replacement: adım 7, 3 resimden 3.
    • Remove the panels covering the power brick and cord.
  8. HP Officejet 4630 Scanner Head Replacement: adım 8, 2 resimden 1. HP Officejet 4630 Scanner Head Replacement: adım 8, 2 resimden 2.
    • Remove the cord from the power supply.
  9. HP Officejet 4630 Scanner Head Replacement: adım 9, 3 resimden 1. HP Officejet 4630 Scanner Head Replacement: adım 9, 3 resimden 2. HP Officejet 4630 Scanner Head Replacement: adım 9, 3 resimden 3.
    • Slide the power supply out from the chassis.
    • The power supply is still attached; don't pull too quickly.
  10. HP Officejet 4630 Scanner Head Replacement: adım 10, 1 resimden 1.
    • Remove final cable from power supply.
  11. HP Officejet 4630 Scanner Head Replacement, Scanner Head: adım 11, 1 resimden 1.
    • Remove eight T10 1mm screws from the top hood of the printer.
  12. HP Officejet 4630 Scanner Head Replacement: adım 12, 3 resimden 1. HP Officejet 4630 Scanner Head Replacement: adım 12, 3 resimden 2. HP Officejet 4630 Scanner Head Replacement: adım 12, 3 resimden 3.
    • Use the nylon spudger to pry the tab.
    • Lift up the entire panel.
  13. HP Officejet 4630 Scanner Head Replacement: adım 13, 3 resimden 1. HP Officejet 4630 Scanner Head Replacement: adım 13, 3 resimden 2. HP Officejet 4630 Scanner Head Replacement: adım 13, 3 resimden 3.
    • Lift and flip the entire panel.
    • Be aware of the scanner head attached to the panel.
  14. HP Officejet 4630 Scanner Head Replacement: adım 14, 3 resimden 1. HP Officejet 4630 Scanner Head Replacement: adım 14, 3 resimden 2. HP Officejet 4630 Scanner Head Replacement: adım 14, 3 resimden 3.
    • Start with the scanner head in place.
    • Unwind the ribbon from the track.
    • Detach ribbon completely.
Sonuç
Maya Willis
418 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G3, Livingston Winter 2018 Cal Poly, Team S18-G3, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S18G3
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 1,650
