Ana içeriğe geç
HP Officejet J3680 Speaker Replacement
Neye ihtiyacın var
  1. HP Officejet J3680 Speaker Replacement, Unplug the Device: adım 1, 1 resimden 1.
    • Remove the plug from the outlet and from the back of the device
    • Remove the USB Cable from your computer and from the back of the device.
  2. HP Officejet J3680 Speaker Replacement, Remove Screws From Under the Control Panel: adım 2, 1 resimden 1.
    • Using your Torx T10 screwdriver, remove the screws indicated in the picture. Screws are 13mm in length.
  3. HP Officejet J3680 Speaker Replacement, Remove Screws Underneath the Ink Cartridge Cover: adım 3, 1 resimden 1.
  4. HP Officejet J3680 Speaker Replacement, Remove Screws from Underneath the Phone Panel: adım 4, 1 resimden 1.
    • In step 2, you removed the screw from the blue indicated area.
    • Gently pop off the black cover that the phone rests on. Underneath this cover, you will find two more screws.
  5. HP Officejet J3680 Speaker Replacement, Remove the Screws from the Rear of Device: adım 5, 1 resimden 1.
  6. HP Officejet J3680 Speaker Replacement, Remove Rear Plastic Panel: adım 6, 1 resimden 1.
    • Once the rear plastic panel has been removed, you are ready to replace and repair the necessary parts.
  7. HP Officejet J3680 Speaker Replacement, Unscrew the speaker: adım 7, 1 resimden 1.
    • Using your Torx t10 screwdriver, remove the screw located on the right side of the speaker as shown in the figure on the left. The screw is 13mm in length.
  8. HP Officejet J3680 Speaker Replacement, Detatch the speaker: adım 8, 1 resimden 1.
    • Follow the wires, connected to the speaker, to the green mother board.
    • Then detach the white plastic piece connected to the wires, shown on the left, by gently pulling it out from the motherboard.
Sonuç
Marisa
206 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Duarte Fall 2014 UMass Dartmouth, Team 1-1, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S1G1
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 274
