Ana içeriğe geç
HP Officejet Pro 6230 Printer Power Adaptor Replacement
Neye ihtiyacın var
  1. HP Officejet Pro 6230 Printer Power Adaptor Replacement, Power Adapter: adım 1, 2 resimden 1. HP Officejet Pro 6230 Printer Power Adaptor Replacement, Power Adapter: adım 1, 2 resimden 2.
    • Turn the printer around and locate the back panel for power.
    • Note: If you are unsure where the panel is located, look in the back right corner. The panel has “100-240V~50/60 Hz 700 mA” inscribed on it.
  2. HP Officejet Pro 6230 Printer Power Adaptor Replacement: adım 2, 1 resimden 1.
    • Unscrew the 0.8 mm screw holding in the panel using a T6 Torx screwdriver.
    • Note: Rotate the screw counterclockwise to loosen. Keep it in a safe place.
  3. HP Officejet Pro 6230 Printer Power Adaptor Replacement: adım 3, 1 resimden 1.
    • Remove the HP AC Power Adapter from the slot.
  4. HP Officejet Pro 6230 Printer Power Adaptor Replacement: adım 4, 1 resimden 1.
    • Locate the blue/green/red wire attached to the back of the adapter.
  5. HP Officejet Pro 6230 Printer Power Adaptor Replacement: adım 5, 1 resimden 1.
    • Unplug the current adapter from the wire.
    • Grasp the end of the connector, not the wires, to pull it out.
  6. HP Officejet Pro 6230 Printer Power Adaptor Replacement: adım 6, 1 resimden 1.
    • Affix the new adapter to the same wire.
Sonuç
Natalie Carmona
101 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 1,114
