Ana içeriğe geç
HP Officejet Pro 6835 AC Power Adapter Replacement
Neye ihtiyacın var
  1. HP Officejet Pro 6835 AC Power Adapter Replacement, AC Power Adapter: adım 1, 3 resimden 1. HP Officejet Pro 6835 AC Power Adapter Replacement, AC Power Adapter: adım 1, 3 resimden 2. HP Officejet Pro 6835 AC Power Adapter Replacement, AC Power Adapter: adım 1, 3 resimden 3.
    • Use a T9 torx screwdriver to remove one (1) 10mm screw by turning it counterclockwise.
    • Grab the backplate and pull it towards you to remove it.
  2. HP Officejet Pro 6835 AC Power Adapter Replacement: adım 2, 1 resimden 1.
    • Grab the AC Power Adapter and pull it towards you to slide it out.
  3. HP Officejet Pro 6835 AC Power Adapter Replacement: adım 3, 1 resimden 1.
    • Grab the base of the colored, braided cable and pull it out of the AC Power Adapter.
Sonuç
Jake Park
465 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G4, Livingston Winter 2018 Cal Poly, Team S2-G4, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S2G4
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 720
