Ana içeriğe geç
HP Officejet Pro 6835 Carriage Belt Replacement
Neye ihtiyacın var
  1. HP Officejet Pro 6835 Carriage Belt Replacement, HP Officejet Pro 6835 Cover Disassembly: adım 1, 1 resimden 1.
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Carriage Belt Replacement: adım 2, 3 resimden 1. HP Officejet Pro 6835 Carriage Belt Replacement: adım 2, 3 resimden 2. HP Officejet Pro 6835 Carriage Belt Replacement: adım 2, 3 resimden 3.
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Carriage Belt Replacement: adım 3, 1 resimden 1.
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Carriage Belt Replacement: adım 4, 2 resimden 1. HP Officejet Pro 6835 Carriage Belt Replacement: adım 4, 2 resimden 2.
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Carriage Belt Replacement, Printhead: adım 5, 2 resimden 1. HP Officejet Pro 6835 Carriage Belt Replacement, Printhead: adım 5, 2 resimden 2.
    • Using tweezers, pinch the top of the spring located on the right side of the printhead.
    • Pull the spring up and around the hook of the carriage to remove the spring from the printhead.
    • Use the same procedure to remove the left spring.
    • The springs may fly out of the printer once you remove them.
  6. HP Officejet Pro 6835 Carriage Belt Replacement: adım 6, 3 resimden 1. HP Officejet Pro 6835 Carriage Belt Replacement: adım 6, 3 resimden 2. HP Officejet Pro 6835 Carriage Belt Replacement: adım 6, 3 resimden 3.
    • Pinch the left most white cable located on the back of the printhead with your tweezers.
    • Pull the cable to remove it from the printhead.
    • Continue this process to remove all three white cable from the printhead.
  7. HP Officejet Pro 6835 Carriage Belt Replacement: adım 7, 3 resimden 1. HP Officejet Pro 6835 Carriage Belt Replacement: adım 7, 3 resimden 2. HP Officejet Pro 6835 Carriage Belt Replacement: adım 7, 3 resimden 3.
    • Lift the printhead off the printer to expose the last white cable.
    • Pinch the the last cable with the tweezers.
    • Pull the cable to disconnect it from the printhead.
  8. HP Officejet Pro 6835 Carriage Belt Replacement, Carriage Belt: adım 8, 3 resimden 1. HP Officejet Pro 6835 Carriage Belt Replacement, Carriage Belt: adım 8, 3 resimden 2. HP Officejet Pro 6835 Carriage Belt Replacement, Carriage Belt: adım 8, 3 resimden 3.
    • Using the tweezers, remove the right side of the metal clamp that is holding the metal frame in place by pulling up.
    • With the tweezers, unhook the metal coil side of the clamp and pull up to remove it completely.
    • Repeat these steps on the other side of the printer.
  9. HP Officejet Pro 6835 Carriage Belt Replacement: adım 9, 1 resimden 1.
    • On the right side of the printer, remove the screw (6mm T9) holding the carriage belt wheel by turning the screwdriver counterclockwise.
  10. HP Officejet Pro 6835 Carriage Belt Replacement: adım 10, 1 resimden 1.
    • Using the tweezers, remove the metal clamp directly under the screw that was just removed by pulling up.
  11. HP Officejet Pro 6835 Carriage Belt Replacement: adım 11, 2 resimden 1. HP Officejet Pro 6835 Carriage Belt Replacement: adım 11, 2 resimden 2.
    • Using one hand, loosen the carriage belt around the wheel by compressing the spring against the wheel.
    • While still compressing the spring, use your other hand to grab the spring and wheel and pull up to remove them.
  12. HP Officejet Pro 6835 Carriage Belt Replacement: adım 12, 1 resimden 1.
    • Unwrap the carriage belt from the hook on the other side of the printer using the tweezers by pulling to the left and up.
  13. HP Officejet Pro 6835 Carriage Belt Replacement: adım 13, 2 resimden 1. HP Officejet Pro 6835 Carriage Belt Replacement: adım 13, 2 resimden 2.
    • Grab the metal rod connected to the carriage.
    • Push the rod to the left and lift up the right end.
    • Lift the metal rod completely out of the printer by lifting straight up, and slide the rod out of the carriage by pushing the left end to the right.
  14. HP Officejet Pro 6835 Carriage Belt Replacement: adım 14, 2 resimden 1. HP Officejet Pro 6835 Carriage Belt Replacement: adım 14, 2 resimden 2.
    • Flip the carriage upside down.
    • Using the metal tweezers, remove the clamp over the carriage belt by first pulling up on the back of the clamp, then on the front.
  15. HP Officejet Pro 6835 Carriage Belt Replacement: adım 15, 1 resimden 1.
    • Remove the carriage belt by holding the carriage in one hand and pulling the carriage belt up with the other.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elena Fowler
445 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G4, Livingston Winter 2018 Cal Poly, Team S2-G4, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S2G4
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 28
Her zaman: 1,762
