Ana içeriğe geç
HP Officejet Pro 6835 Speaker Replacement
Neye ihtiyacın var
  1. HP Officejet Pro 6835 Speaker Replacement, HP Officejet Pro 6835 Cover Disassembly: adım 1, 1 resimden 1.
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Speaker Replacement: adım 2, 3 resimden 1. HP Officejet Pro 6835 Speaker Replacement: adım 2, 3 resimden 2. HP Officejet Pro 6835 Speaker Replacement: adım 2, 3 resimden 3.
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Speaker Replacement: adım 3, 1 resimden 1.
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Speaker Replacement: adım 4, 2 resimden 1. HP Officejet Pro 6835 Speaker Replacement: adım 4, 2 resimden 2.
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Speaker Replacement, Speaker: adım 5, 3 resimden 1. HP Officejet Pro 6835 Speaker Replacement, Speaker: adım 5, 3 resimden 2. HP Officejet Pro 6835 Speaker Replacement, Speaker: adım 5, 3 resimden 3.
    • Grab the intertwined red and black wires. Gently pull up and disconnect the wires from the motherboard.
    • Be careful to remove the wires from the socket, NOT the socket from the board.
  6. HP Officejet Pro 6835 Speaker Replacement: adım 6, 1 resimden 1.
    • Carefully slide the speaker out of the printer.
Sonuç
David J
169 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G4, Livingston Winter 2018 Cal Poly, Team S2-G4, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S2G4
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 268
