Ana içeriğe geç
HP Officejet Pro 8600 Plus Battery Replacement
Neye ihtiyacın var
  1. HP Officejet Pro 8600 Plus Battery Replacement, Motherboard: adım 1, 2 resimden 1. HP Officejet Pro 8600 Plus Battery Replacement, Motherboard: adım 1, 2 resimden 2.
    • Turn the printer so the back is facing you.
    • Put the printer in a vertical position by lifting its right side.
  2. HP Officejet Pro 8600 Plus Battery Replacement: adım 2, 1 resimden 1.
    • Remove the two 12mm T10 Torx screws on the top edge of the printer.
  3. HP Officejet Pro 8600 Plus Battery Replacement: adım 3, 1 resimden 1.
    • Rotate the printer clockwise so the bottom of the printer is facing you.
  4. HP Officejet Pro 8600 Plus Battery Replacement: adım 4, 2 resimden 1. HP Officejet Pro 8600 Plus Battery Replacement: adım 4, 2 resimden 2.
    • Insert the plastic opening tool underneath the slot on the right that aligns with the edge of the back panel.
    • Insert a second plastic opening tool in the notch lining up with the crease in the back panel.
    • This step requires applying a significant amount of force on the left notch. Don't be alarmed if you hear popping noises.
  5. HP Officejet Pro 8600 Plus Battery Replacement: adım 5, 1 resimden 1.
    • Remove the side panel from the printer by lifting upwards toward you.
    • For reassembly, slide the side panel from left to right into place.
  6. HP Officejet Pro 8600 Plus Battery Replacement: adım 6, 1 resimden 1.
    • Remove the four 6.5 mm T10 Torx screws from the motherboard.
  7. HP Officejet Pro 8600 Plus Battery Replacement: adım 7, 1 resimden 1.
    • Remove the black brace from the right side of the motherboard, located near the black ribbon cable.
  8. HP Officejet Pro 8600 Plus Battery Replacement: adım 8, 3 resimden 1. HP Officejet Pro 8600 Plus Battery Replacement: adım 8, 3 resimden 2. HP Officejet Pro 8600 Plus Battery Replacement: adım 8, 3 resimden 3.
    • Remove the cables connected to the top of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the edge of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the underside of the motherboard by gently pulling them out of their ports.
  9. HP Officejet Pro 8600 Plus Battery Replacement, Battery: adım 9, 2 resimden 1. HP Officejet Pro 8600 Plus Battery Replacement, Battery: adım 9, 2 resimden 2.
    • Turn the motherboard over so the back is facing upward.
    • Use the plastic opening tool to pry the battery out of place.
  10. HP Officejet Pro 8600 Plus Battery Replacement: adım 10, 1 resimden 1.
    • Remove the battery by grabbing its edges, lifting upward, and sliding sideways.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Mackinnon Buck
1.182 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S16-G4, Livingston Spring 2018 Cal Poly, Team S16-G4, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S16G4
4 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Are there any procedures required after either battery replacement or motherboard replacement? Re-loading of firmware, initialization, etc. Does the printer's serial number change as a result of battery replacement or motherboard replacement?
Erik Fjerstad - Yanıt
Bonjour ,
ma batterie est ok , par contre la courroie s'effiloche.
Peut on la remplacer et si oui comment y accéder?
J'ai déplacé le tendeur pour augmenter la tension de la courroie mais ce n'est pas suffisant.
Merci
BàV phil
Philippe Herbots - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 62
Her zaman: 5,287
