Ana içeriğe geç
HP Officejet Pro 8600 Plus Front Panel Replacement
Neye ihtiyacın var
  1. HP Officejet Pro 8600 Plus Front Panel Replacement, Front Panel: adım 1, 2 resimden 1. HP Officejet Pro 8600 Plus Front Panel Replacement, Front Panel: adım 1, 2 resimden 2.
    • Open the front panel door by pulling forward on the slot located on the front-left side of the printer.
  2. HP Officejet Pro 8600 Plus Front Panel Replacement: adım 2, 2 resimden 1. HP Officejet Pro 8600 Plus Front Panel Replacement: adım 2, 2 resimden 2.
    • Insert the plastic opening tool into the right socket connecting the front panel door to the hinge guide.
    • Pry the socket open, lifting the door hinge guide out of place.
  3. HP Officejet Pro 8600 Plus Front Panel Replacement: adım 3, 2 resimden 1. HP Officejet Pro 8600 Plus Front Panel Replacement: adım 3, 2 resimden 2.
    • Pull the door-hinge guide to the right to detach its left socket.
    • Lift the door-hinge guide upward and away from the front panel door.
  4. HP Officejet Pro 8600 Plus Front Panel Replacement: adım 4, 2 resimden 1. HP Officejet Pro 8600 Plus Front Panel Replacement: adım 4, 2 resimden 2.
    • Grab the front panel door close to its hinge on the right side.
    • Pull the front panel door away from the printer toward you.
    • Extra force may be required to pull the door from its hinge.
  5. HP Officejet Pro 8600 Plus Front Panel Replacement: adım 5, 3 resimden 1. HP Officejet Pro 8600 Plus Front Panel Replacement: adım 5, 3 resimden 2. HP Officejet Pro 8600 Plus Front Panel Replacement: adım 5, 3 resimden 3.
    • Grab the front panel door close to its two hinges on the left side.
    • Extra force may be required to pull the door from its hinges.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Maegan Betz
301 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S16-G4, Livingston Spring 2018 Cal Poly, Team S16-G4, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S16G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 3,733
