Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
HP Officejet Pro 8620 Power Adapter Replacement
Neye ihtiyacın var
    1. HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: adım 1, 3 resimden 1. HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: adım 1, 3 resimden 2. HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: adım 1, 3 resimden 3.
      • Turn off the printer and remove the power cable.
      • Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
      FixBot'a Sor
      Yorum Ekle
    2. HP Officejet Pro 8620 Power Adapter Replacement: adım 2, 2 resimden 1. HP Officejet Pro 8620 Power Adapter Replacement: adım 2, 2 resimden 2.
      • Open the front door by placing your finger on the indented groove on the left side of the printer and pulling down
      • This will give you access to the two T9-TORX 13mm screws that need to be removed to release the panel.
      FixBot'a Sor
      Yorum Ekle
    3. HP Officejet Pro 8620 Power Adapter Replacement: adım 3, 2 resimden 1. HP Officejet Pro 8620 Power Adapter Replacement: adım 3, 2 resimden 2.
      • Remove the two 13mm screws with a T9-TORX screwdriver by turning counter-clockwise (left).
      FixBot'a Sor
      Yorum Ekle
    4. HP Officejet Pro 8620 Power Adapter Replacement: adım 4, 3 resimden 1. HP Officejet Pro 8620 Power Adapter Replacement: adım 4, 3 resimden 2. HP Officejet Pro 8620 Power Adapter Replacement: adım 4, 3 resimden 3.
      • Gently remove the left side panel by placing your palm flat against the surface and pulling down.
      FixBot'a Sor
      Yorum Ekle
    1. HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: adım 5, 3 resimden 1. HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: adım 5, 3 resimden 2. HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: adım 5, 3 resimden 3.
      • Remove two screws 13mm screws with a T9-Torx screwdriver by rotating them counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    2. HP Officejet Pro 8620 Power Adapter Replacement: adım 6, 3 resimden 1. HP Officejet Pro 8620 Power Adapter Replacement: adım 6, 3 resimden 2. HP Officejet Pro 8620 Power Adapter Replacement: adım 6, 3 resimden 3.
      • Unplug the black cable .
      • Move all the cables and wires to the top of the motherboard to allow the power adapter underneath to be removed freely.
      FixBot'a Sor
      Yorum Ekle
    3. HP Officejet Pro 8620 Power Adapter Replacement: adım 7, 1 resimden 1.
      • Gently bend the black ribbon cable.
      • Remove one 8mm T8 screw underneath the ribbon cable by rotating it counterclockwise with a T8 -Torx screwdriver.
      • Take out the black plastic cover and the colored wires connected to it.
      • Now you have cleared a passage for the power adapter to be taken out.
      FixBot'a Sor
      Yorum Ekle
    4. HP Officejet Pro 8620 Power Adapter Replacement: adım 8, 1 resimden 1.
      • Gently pulling out the power adapter.
      • Be careful with all the wires when pulling out the adapter.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Scott
656 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G2, Livingston Spring 2018 Cal Poly, Team S19-G2, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S19G2
1 Üye
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 27
Her zaman: 2,765
