Ana içeriğe geç
HP Officejet Pro 8620 Power Adapter Replacement
Neye ihtiyacın var
  1. HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: adım 1, 3 resimden 1. HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: adım 1, 3 resimden 2. HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: adım 1, 3 resimden 3.
    • Turn off the printer and remove the power cable.
    • Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
  2. HP Officejet Pro 8620 Power Adapter Replacement: adım 2, 2 resimden 1. HP Officejet Pro 8620 Power Adapter Replacement: adım 2, 2 resimden 2.
    • Open the front door by placing your finger on the indented groove on the left side of the printer and pulling down
    • This will give you access to the two T9-TORX 13mm screws that need to be removed to release the panel.
  3. HP Officejet Pro 8620 Power Adapter Replacement: adım 3, 2 resimden 1. HP Officejet Pro 8620 Power Adapter Replacement: adım 3, 2 resimden 2.
    • Remove the two 13mm screws with a T9-TORX screwdriver by turning counter-clockwise (left).
  4. HP Officejet Pro 8620 Power Adapter Replacement: adım 4, 3 resimden 1. HP Officejet Pro 8620 Power Adapter Replacement: adım 4, 3 resimden 2. HP Officejet Pro 8620 Power Adapter Replacement: adım 4, 3 resimden 3.
    • Gently remove the left side panel by placing your palm flat against the surface and pulling down.
  5. HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: adım 5, 3 resimden 1. HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: adım 5, 3 resimden 2. HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: adım 5, 3 resimden 3.
    • Remove two screws 13mm screws with a T9-Torx screwdriver by rotating them counterclockwise.
  6. HP Officejet Pro 8620 Power Adapter Replacement: adım 6, 3 resimden 1. HP Officejet Pro 8620 Power Adapter Replacement: adım 6, 3 resimden 2. HP Officejet Pro 8620 Power Adapter Replacement: adım 6, 3 resimden 3.
    • Unplug the black cable .
    • Move all the cables and wires to the top of the motherboard to allow the power adapter underneath to be removed freely.
  7. HP Officejet Pro 8620 Power Adapter Replacement: adım 7, 1 resimden 1.
    • Gently bend the black ribbon cable.
    • Remove one 8mm T8 screw underneath the ribbon cable by rotating it counterclockwise with a T8 -Torx screwdriver.
    • Take out the black plastic cover and the colored wires connected to it.
    • Now you have cleared a passage for the power adapter to be taken out.
  8. HP Officejet Pro 8620 Power Adapter Replacement: adım 8, 1 resimden 1.
    • Gently pulling out the power adapter.
    • Be careful with all the wires when pulling out the adapter.
Sonuç
Scott
593 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G2, Livingston Spring 2018 Cal Poly, Team S19-G2, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S19G2
1 Üye
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 32
Her zaman: 2,349
