Ana içeriğe geç
HP Officejet Pro 8620 Power Button Replacement
Neye ihtiyacın var
    1. HP Officejet Pro 8620 Power Button Replacement, Power Button: adım 1, 3 resimden 1. HP Officejet Pro 8620 Power Button Replacement, Power Button: adım 1, 3 resimden 2. HP Officejet Pro 8620 Power Button Replacement, Power Button: adım 1, 3 resimden 3.
      • Locate the power button on the bottom left side of the device.
      • Wedge the opening tool into the small gap between the power button panel and printer.
      • Apply pressure on the opening tool and open the power button panel.
      • Gently remove the power button panel assembly from the printer to access the power button.
      FixBot'a Sor
      Yorum Ekle
    2. HP Officejet Pro 8620 Power Button Replacement: adım 2, 2 resimden 1. HP Officejet Pro 8620 Power Button Replacement: adım 2, 2 resimden 2.
      • Press on the power button from the front of the panel to release it.
      FixBot'a Sor
      Yorum Ekle
    3. HP Officejet Pro 8620 Power Button Replacement: adım 3, 2 resimden 1. HP Officejet Pro 8620 Power Button Replacement: adım 3, 2 resimden 2.
      • Turn the panel around so you are viewing the back of it.
      • Disconnect the power button from the panel by gently pulling the button out (toward your body).
      • Be careful not to crack the connector of the button panel when pulling the power button
      FixBot'a Sor
      Yorum Ekle
Sonuç
Scott
656 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G2, Livingston Spring 2018 Cal Poly, Team S19-G2, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S19G2
1 Üye
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 33
Her zaman: 3,201
