Ana içeriğe geç
HP Officejet Pro 8625 Motherboard Replacement
Neye ihtiyacın var
  1. HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: adım 1, 3 resimden 1. HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: adım 1, 3 resimden 2. HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: adım 1, 3 resimden 3.
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 Motherboard Replacement: adım 2, 3 resimden 1. HP Officejet Pro 8625 Motherboard Replacement: adım 2, 3 resimden 2. HP Officejet Pro 8625 Motherboard Replacement: adım 2, 3 resimden 3.
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 Motherboard Replacement: adım 3, 2 resimden 1. HP Officejet Pro 8625 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. HP Officejet Pro 8625 Motherboard Replacement, Motherboard: adım 4, 3 resimden 1. HP Officejet Pro 8625 Motherboard Replacement, Motherboard: adım 4, 3 resimden 2. HP Officejet Pro 8625 Motherboard Replacement, Motherboard: adım 4, 3 resimden 3.
    • Remove the three 5.3 mm T9 screws from the motherboard.
    • Remove the one 6.7 mm T9 screw from the motherboard.
  5. HP Officejet Pro 8625 Motherboard Replacement: adım 5, 2 resimden 1. HP Officejet Pro 8625 Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the connectors from the front and sides of the motherboard by pulling straight away from the connection.
  6. HP Officejet Pro 8625 Motherboard Replacement: adım 6, 3 resimden 1. HP Officejet Pro 8625 Motherboard Replacement: adım 6, 3 resimden 2. HP Officejet Pro 8625 Motherboard Replacement: adım 6, 3 resimden 3.
    • Lift the bottom of the motherboard and remove the connectors from the back.
    • Remove the motherboard.
    • There are two white connectors underneath the motherboard, remove them separately.
Sonuç
Cam Engle
531 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G3, White Fall 2018 Cal Poly, Team S13-G3, White Fall 2018 üyesi
CPSU-WHITE-F18S13G3
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 480
