Ana içeriğe geç
HP Officejet Pro 8625 Printhead Replacement
Neye ihtiyacın var
  1. HP Officejet Pro 8625 Printhead Replacement, Left Side Panel: adım 1, 3 resimden 1. HP Officejet Pro 8625 Printhead Replacement, Left Side Panel: adım 1, 3 resimden 2. HP Officejet Pro 8625 Printhead Replacement, Left Side Panel: adım 1, 3 resimden 3.
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 Printhead Replacement: adım 2, 3 resimden 1. HP Officejet Pro 8625 Printhead Replacement: adım 2, 3 resimden 2. HP Officejet Pro 8625 Printhead Replacement: adım 2, 3 resimden 3.
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 Printhead Replacement: adım 3, 2 resimden 1. HP Officejet Pro 8625 Printhead Replacement: adım 3, 2 resimden 2.
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. HP Officejet Pro 8625 Printhead Replacement, Printhead: adım 4, 2 resimden 1. HP Officejet Pro 8625 Printhead Replacement, Printhead: adım 4, 2 resimden 2.
    • Remove the one 5.3 mm T9 screw.
  5. HP Officejet Pro 8625 Printhead Replacement: adım 5, 2 resimden 1. HP Officejet Pro 8625 Printhead Replacement: adım 5, 2 resimden 2.
    • Remove the four connectors from the top of the motherboard.
  6. HP Officejet Pro 8625 Printhead Replacement: adım 6, 2 resimden 1. HP Officejet Pro 8625 Printhead Replacement: adım 6, 2 resimden 2.
    • Remove the three 11.6 mm T9 screws from the top, back of the printer.
    • Remove the one 12.1 mm T9 screw from the top, back of the printer.
  7. HP Officejet Pro 8625 Printhead Replacement: adım 7, 2 resimden 1. HP Officejet Pro 8625 Printhead Replacement: adım 7, 2 resimden 2.
    • Remove the 11.6mm T9 screw from the top left of the front of the printer.
  8. HP Officejet Pro 8625 Printhead Replacement: adım 8, 1 resimden 1.
    • Disconnect the display by pulling down on the plastic hinge.
    • Gradually apply more force to the hinge and don't worry about the hinge or display breaking.
  9. HP Officejet Pro 8625 Printhead Replacement: adım 9, 3 resimden 1. HP Officejet Pro 8625 Printhead Replacement: adım 9, 3 resimden 2. HP Officejet Pro 8625 Printhead Replacement: adım 9, 3 resimden 3.
    • Lift the display as high as it will allow to expose the back of the display.
    • Remove the connector by pinching the sides and pulling away from the printer.
    • Remove the connector by pulling both away from the display and towards the printer.
  10. HP Officejet Pro 8625 Printhead Replacement: adım 10, 2 resimden 1. HP Officejet Pro 8625 Printhead Replacement: adım 10, 2 resimden 2.
    • Remove the two 11.6 mm T9 screws from beneath the display.
  11. HP Officejet Pro 8625 Printhead Replacement: adım 11, 1 resimden 1.
    • Remove the top of the printer by lifting it from both sides.
  12. HP Officejet Pro 8625 Printhead Replacement: adım 12, 3 resimden 1. HP Officejet Pro 8625 Printhead Replacement: adım 12, 3 resimden 2. HP Officejet Pro 8625 Printhead Replacement: adım 12, 3 resimden 3.
    • Locate the printhead on the right side of the printer.
    • Pull the white tab on the right side of the printhead up, by pushing on the side of the printer a little bit.
    • Remove the printhead by lifting it out of the housing.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Cam Engle
531 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G3, White Fall 2018 Cal Poly, Team S13-G3, White Fall 2018 üyesi
CPSU-WHITE-F18S13G3
3 Üyeler
14 adet Kılavuz yazıldı
5 Yorum
This printhead is normally user replaceable.
No screwdrivers are required.
This video is for an 8600, but the process is the same.
https://www.youtube.com/watch?v=i-IluLvF...
Andy - Yanıt
I used these instructions to repair the guide ribbon for the print head. It had come off after a sheet of high tack labels got jammed in the printer. Just saved myself from having to buy a new printer! Thanks!!!
Robert de Salazar - Yanıt
12 steps not necessary. Just open the front (like changing ink) and lift the grey lever referenced in step 12, then remove the head from the carriage.
bwaaronj - Yanıt
Correct. So easy.
hinz -
BWAARONJ, I did exactly what you suggested in my 8625 three times! Now my printer is in pieces and parts, and I cannot get the printhead to release from the right side of the housing. I was very meticulous in making an effort to correct this problem, but, alas, it appears I will have to get a new printer!
Shelia Guy Bozeman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 22
Son 30 gün: 78
Her zaman: 7,769
