Ana içeriğe geç
HP Omen 15-5002xx Battery Replacement
Neye ihtiyacın var
  1. HP Omen 15-5002xx Battery Replacement, Back Cover: adım 1, 2 resimden 1. HP Omen 15-5002xx Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Battery Replacement, Battery: adım 2, 1 resimden 1.
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Battery Replacement: adım 3, 2 resimden 1. HP Omen 15-5002xx Battery Replacement: adım 3, 2 resimden 2.
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
Sonuç
Eduardo Arellano
621 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Saknee Fall 2021 Gateway, Team 1-1, Saknee Fall 2021 üyesi
GCC-SAKNEE-F21S1G1
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 574
