Ana içeriğe geç
HP Omen 15-ax200ne Hard Drive Replacement
Neye ihtiyacın var
  1. HP Omen 15-ax200ne Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Fully power off the laptop.
    • If you are unsure that your laptop is in hibernation mode, turn the computer off from the start menu.
    • Unplug charging cable and any external devices.
  2. HP Omen 15-ax200ne Hard Drive Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Position the laptop upside down on a flat and clean surface.
    • Make sure to stay away from static discharge or wear an anti-static wrist strap.
    • Remove the two Phillips M2x5.0 screws located at the top left and top right of the laptop (circled in red).
    • Remove the eight M2.5x6.0 (circled in orange).
  3. HP Omen 15-ax200ne Hard Drive Replacement: adım 3, 2 resimden 1. HP Omen 15-ax200ne Hard Drive Replacement: adım 3, 2 resimden 2.
    • Keep in mind, there are three internal clips by the battery area.
    • Slide the nylon opening tool around the edge of the base enclosure, releasing the three clips by the battery area.
    • Continue to slide the nylon opening tool around the edges of the base enclosure, doing so while loosen the cover.
  4. HP Omen 15-ax200ne Hard Drive Replacement: adım 4, 2 resimden 1. HP Omen 15-ax200ne Hard Drive Replacement: adım 4, 2 resimden 2.
    • After successfully loosening the base enclosure, and removing it. You will be left with an exposed motherboard.
  5. HP Omen 15-ax200ne Hard Drive Replacement: adım 5, 3 resimden 1. HP Omen 15-ax200ne Hard Drive Replacement: adım 5, 3 resimden 2. HP Omen 15-ax200ne Hard Drive Replacement: adım 5, 3 resimden 3.
    • Unplug the battery from the motherboard.
    • Release the battery cable from the routing channel to reveal the screws beneath.
  6. HP Omen 15-ax200ne Hard Drive Replacement: adım 6, 3 resimden 1. HP Omen 15-ax200ne Hard Drive Replacement: adım 6, 3 resimden 2. HP Omen 15-ax200ne Hard Drive Replacement: adım 6, 3 resimden 3.
    • Remove the four 2x5 screws using the Phillips screwdriver.
    • Slide the battery out of its space to remove it from the computer.
  7. HP Omen 15-ax200ne Hard Drive Replacement: adım 8, 3 resimden 1. HP Omen 15-ax200ne Hard Drive Replacement: adım 8, 3 resimden 2. HP Omen 15-ax200ne Hard Drive Replacement: adım 8, 3 resimden 3.
    • Disconnect the clip attaching the hard drive cable to the motherboard.
    • Be careful when disconnecting this clip, as it is very delicate.
    • Use your fingers or a spudger to disconnect the cable. Do not use a screwdriver for the job. It could cause damage.
    • Slide the hard drive out horizontally.
  8. HP Omen 15-ax200ne Hard Drive Replacement: adım 9, 1 resimden 1.
    • Disassemble the hard drive by removing the connector and the side brackets.
  9. HP Omen 15-ax200ne Hard Drive Replacement: adım 10, 2 resimden 1. HP Omen 15-ax200ne Hard Drive Replacement: adım 10, 2 resimden 2.
    • Reattach the side brackets and the hard drive connector.
  10. HP Omen 15-ax200ne Hard Drive Replacement: adım 11, 2 resimden 1. HP Omen 15-ax200ne Hard Drive Replacement: adım 11, 2 resimden 2.
    • Slide the hard drive back to the original spot.
    • Reclip the hard drive to the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 37
Son 30 gün: 183
Her zaman: 3,833
