Ana içeriğe geç
HP Omen 15-ax243dx Hard-Drive Replacement
Neye ihtiyacın var
  1. HP Omen 15-ax243dx Hard-Drive Replacement, Battery: adım 1, 2 resimden 1. HP Omen 15-ax243dx Hard-Drive Replacement, Battery: adım 1, 2 resimden 2.
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Hard-Drive Replacement: adım 2, 2 resimden 1. HP Omen 15-ax243dx Hard-Drive Replacement: adım 2, 2 resimden 2.
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Hard-Drive Replacement: adım 3, 2 resimden 1. HP Omen 15-ax243dx Hard-Drive Replacement: adım 3, 2 resimden 2.
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Hard-Drive Replacement: adım 4, 2 resimden 1. HP Omen 15-ax243dx Hard-Drive Replacement: adım 4, 2 resimden 2.
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Hard-Drive Replacement, Hard-Drive: adım 5, 1 resimden 1.
    • After the battery is removed, the hard drive will be easier to access in the top right hand corner.
  6. HP Omen 15-ax243dx Hard-Drive Replacement: adım 6, 3 resimden 1. HP Omen 15-ax243dx Hard-Drive Replacement: adım 6, 3 resimden 2. HP Omen 15-ax243dx Hard-Drive Replacement: adım 6, 3 resimden 3.
    • With a opening tool, flip open the switch that locks in the hard drive ribbon cable into the device.
    • When lifting the cable out, lift straight up and out to prevent damage to the connector or cable.
  7. HP Omen 15-ax243dx Hard-Drive Replacement: adım 7, 1 resimden 1.
    • Lift the hard drive up to remove from the device
  8. HP Omen 15-ax243dx Hard-Drive Replacement: adım 8, 3 resimden 1. HP Omen 15-ax243dx Hard-Drive Replacement: adım 8, 3 resimden 2. HP Omen 15-ax243dx Hard-Drive Replacement: adım 8, 3 resimden 3.
    • Remove the rubber guards on the side of the hard drive.
    • Gently pull the plastic connector out from the hard drive.
    • The hard drive can now be disposed of if needed.
    • Save the guards and connectors from this hard drive, they will be used on the replacement part.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
vangnam
594 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 UMass Dartmouth, Team S6-G7, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S6G7
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 53
Her zaman: 8,357
