Giriş
Is the speakers on your HP-Omen computer not working and you found out it costs a lot to have them fixed? Well you are in luck. The following guide consist of the 20 total steps to remove the speakers from the computer while also showing you the pre-requeste steps to be able to remove the speakers. You will be removing the battery, hard-drive, ventilation fans and disconnecting the mother board from the laptop. You will only need two types of tools, a Philips #00 screw-driver and a plastic opening tool. This guide will take approximately 20-40 minutes to complete and has a moderate difficulty. This guide allows you to to replace your speakers yourself for free rather than having to pay someone to do it.
Neye ihtiyacın var
The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
The screwdriver should be inserted at the same angle as the screws.
After the battery is removed, the hard drive will be easier to access in the top right hand corner.
The two ventilation fans are secured with the system by 5 screws. Unscrew these five 1.2 mm screws using the Phillips #0 screwdriver.
Bir başkası bu kılavuzu tamamladı.
