Ana içeriğe geç
HP Omen 15-ax243dx Ventilation Fans Replacement
Neye ihtiyacın var
  1. HP Omen 15-ax243dx Ventilation Fans Replacement, Battery: adım 1, 2 resimden 1. HP Omen 15-ax243dx Ventilation Fans Replacement, Battery: adım 1, 2 resimden 2.
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Ventilation Fans Replacement: adım 2, 2 resimden 1. HP Omen 15-ax243dx Ventilation Fans Replacement: adım 2, 2 resimden 2.
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Ventilation Fans Replacement: adım 3, 2 resimden 1. HP Omen 15-ax243dx Ventilation Fans Replacement: adım 3, 2 resimden 2.
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Ventilation Fans Replacement: adım 4, 2 resimden 1. HP Omen 15-ax243dx Ventilation Fans Replacement: adım 4, 2 resimden 2.
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Ventilation Fans Replacement, Ventilation Fans: adım 5, 1 resimden 1.
    • The two ventilation fans are secured with the system by 5 screws. Unscrew these five 1.2 mm screws using the Phillips #0 screwdriver.
    • When removing the screws, use a magnetic screwdriver to prevent the screws from falling behind the motherboard
  6. HP Omen 15-ax243dx Ventilation Fans Replacement: adım 6, 2 resimden 1. HP Omen 15-ax243dx Ventilation Fans Replacement: adım 6, 2 resimden 2.
    • After removing all 5 screws, the fans are still connected with the system through 2 cables.
    • Carefully pull the fan cables out of the connectors on the motherboard.
    • Be cautious when pulling by the wires, this can permanently damage the fans beyond repair.
  7. HP Omen 15-ax243dx Ventilation Fans Replacement: adım 7, 1 resimden 1.
    • The fans can now be removed from the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
vangnam
594 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 UMass Dartmouth, Team S6-G7, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S6G7
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 5,588
