Giriş
Fans are not working? Is your laptop overheating? If thats the case, then it is time to replace your fans, with this guide you can do just that. Don't stress this guide only has a total of 7 steps and you can easier replace your ventilation fans in as little as 15 minutes. This guide will only require two tools, a plastic opening tool (the battery and back cover) and a Phillips #00 screwdriver to remove all the screws. Once you complete all the steps, the fans are easy to remove.
Neye ihtiyacın var
The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
The screwdriver should be inserted at the same angle as the screws.
The two ventilation fans are secured with the system by 5 screws. Unscrew these five 1.2 mm screws using the Phillips #0 screwdriver.
4 farklı kişi bu kılavuzu tamamladı.
