Ana içeriğe geç
HP Omni 10 Battery Replacement
Neye ihtiyacın var
  1. HP Omni 10 Battery  Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the back cover from the tablet.
    • The cover is securely fastened to the device and may be difficult to remove.
  2. HP Omni 10 Battery  Replacement: adım 2, 1 resimden 1.
    • Push the black plastic security flaps into an upward position.
    • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
    • Lift the tab on the strip up and pull it across the battery.
    • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
  3. HP Omni 10 Battery  Replacement: adım 3, 1 resimden 1.
    • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
  4. HP Omni 10 Battery  Replacement: adım 4, 2 resimden 1. HP Omni 10 Battery  Replacement: adım 4, 2 resimden 2.
    • Unhook the cord from the edge of the battery.
    • Pull the wire circuit out and down.
  5. HP Omni 10 Battery  Replacement: adım 5, 2 resimden 1. HP Omni 10 Battery  Replacement: adım 5, 2 resimden 2.
    • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alex Miller
345 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Leahy Fall 2016 USF Tampa, Team 1-1, Leahy Fall 2016 üyesi
USFT-LEAHY-F16S1G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 4,034
