Ana içeriğe geç
HP PSC 2355 Button Panel Replacement
Neye ihtiyacın var
  1. HP PSC 2355 Button Panel Replacement, Scanner Lid: adım 1, 1 resimden 1.
    • Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
    FixBot'a Sor
  2. HP PSC 2355 Button Panel Replacement: adım 2, 1 resimden 1.
    • With two hands, grasp the lid on both sides near the hinges and lift straight up to release the lid from each hinge.
    FixBot'a Sor
  3. HP PSC 2355 Button Panel Replacement, Button Panel: adım 3, 1 resimden 1.
    • Once you have removed the scanner lid, locate the finger notch on inside the top left half of the bezel (control) panel.
    FixBot'a Sor
  4. HP PSC 2355 Button Panel Replacement: adım 4, 1 resimden 1.
    • Place your index finger in the notch and lift up to unsnap the panel.
    • Set panel cover aside.
    FixBot'a Sor
  5. HP PSC 2355 Button Panel Replacement: adım 5, 1 resimden 1.
    • Use a T9 torx screwdriver to remove the 0.9 cm screw.
    FixBot'a Sor
  6. HP PSC 2355 Button Panel Replacement: adım 6, 1 resimden 1.
    • From the front of the printer, remove the button panel by pulling it towards you while slightly lifting it up.
    FixBot'a Sor
  7. HP PSC 2355 Button Panel Replacement: adım 7, 1 resimden 1.
    • Disconnect the white ribbon cable by grasping it between your thumb and index finger.
    • Gently pull to release the ribbon from the green circuit board
    FixBot'a Sor
  8. HP PSC 2355 Button Panel Replacement: adım 8, 1 resimden 1.
    • Next, use the flat end of a spudger to pry loose the flat ribbon computer cable by the plastic connection end and carefully separate it from the prongs on the button panel.
    • The entire button panel should now be completely disconnected from the printer.
    FixBot'a Sor
  9. HP PSC 2355 Button Panel Replacement: adım 9, 1 resimden 1.
    • Lay the panel on a flat surface with the backside facing up.
    • Using a T9 torx screwdriver, remove all six 0.7 cm silver screws from the off-white plastic panel.
    FixBot'a Sor
  10. HP PSC 2355 Button Panel Replacement: adım 10, 1 resimden 1.
    • Gently lift the button panel off the plastic backing with rubber button mat.
    FixBot'a Sor
  11. HP PSC 2355 Button Panel Replacement: adım 11, 1 resimden 1.
    • Be careful not to lift out and lose the two clear plastic panel separators (these are not fastened to the panel but can easily fall out of the panel if tilted). These are two small plastic parts that sit near the top right and left portions of the panel.
    • Insert your new button panel. To reassemble your printer, follow these instructions in reverse order.
    FixBot'a Sor
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Patricia
143 İtibar
1 Kılavuz yazıldı
Ekip
TheFixers TheFixers üyesi
Community
2 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 38
Her zaman: 1,253
