Ana içeriğe geç
HP Pavilion 11 x360 Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion 11 x360 Battery Replacement, Remove Screws: adım 1, 2 resimden 1. HP Pavilion 11 x360 Battery Replacement, Remove Screws: adım 1, 2 resimden 2.
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Battery Replacement, Remove Backing: adım 2, 3 resimden 1. HP Pavilion 11 x360 Battery Replacement, Remove Backing: adım 2, 3 resimden 2. HP Pavilion 11 x360 Battery Replacement, Remove Backing: adım 2, 3 resimden 3.
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Battery Replacement, Detach Cable: adım 3, 2 resimden 1. HP Pavilion 11 x360 Battery Replacement, Detach Cable: adım 3, 2 resimden 2.
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Battery Replacement: adım 5, 3 resimden 1. HP Pavilion 11 x360 Battery Replacement: adım 5, 3 resimden 2. HP Pavilion 11 x360 Battery Replacement: adım 5, 3 resimden 3.
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Battery Replacement: adım 6, 2 resimden 1. HP Pavilion 11 x360 Battery Replacement: adım 6, 2 resimden 2.
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Battery Replacement: adım 7, 2 resimden 1. HP Pavilion 11 x360 Battery Replacement: adım 7, 2 resimden 2.
    • Remove the battery.
    directions great, but i cant find a place to buy it. not even on the HP we site. Help please
    dwest5555 - Yanıt
    I found the battery on Amazon
    JoAnne O'Donnell - Yanıt
    Könnten Sie mir bitte sagen, was für ein Akku verwendet worden ist.
    das wäre für mich sehr hilfreich.
    Vielen Dank
    Junior Kuchi - Yanıt
Sonuç
27 farklı kişi bu kılavuzu tamamladı.
Natalie
937 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-9, Maness Winter 2015 Cal Poly, Team 19-9, Maness Winter 2015 üyesi
CPSU-MANESS-W15S19G9
4 Üyeler
12 adet Kılavuz yazıldı
11 Yorum
exellent and easy steps............but......where do i buy battery.....?
Akshay R Manohar - Yanıt
Muy bueno parece facil
mejiawilson - Yanıt
Great step by step explanation. Solid pictures!!! Could not have fixed this without your contribution!!!
Joe Consumidor - Yanıt
Purchased this laptop 28/12/2015 and now its just not switching on at all. I will try the repair instructions but I think it should have lasted a bit longer, what ever the problem is. The store where I bought it have checked the cable for me to see if that was the problem and it wasn’t. They wanted £60 to send it off, to find out the issue before anything was even done. The sales assistant said it could be the battery but he said it should have lasted longer. He basically said if its the motherboard you may as well just throw it out. I am sick of paying £100’s out for electrical items that live very short lives. My daughter bought this with her own money that she had been saving. I would not purchase this make of laptop again and where do I get a replacement battery and how much is that likely to be?
jane coombes - Yanıt
Very good guide, thank you!
FanMac - Yanıt
I replaced the battery but the laptop won't turn up, the power lighr next to the power connector lite up for couple seconds red and then lighted off.. this is the 2nd battery I try, if I put the old battery attempts to start al least but doesn't have enough power to complete the boot. TIA for your comments
William Parra -
*I love the way u are teaching how to open the laptop*
Richard Chukwu - Yanıt
Thanks this was really helpful
William Appeadu-Mensah - Yanıt
Having a difficult time removing the backing. I’ve removed all the screws, but there still some resistance when I try to separate the bottom. Any advice?
Lyttleton Callender - Yanıt
I actually was able to replace the battery by myself with your excellent guide and I am 80 years old.
Thank you
Joanne 4/6/2020
Fantastic guide ideal for a first time NoteBook fix
Paul Malyjurek - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 78
Her zaman: 59,268
