Ana içeriğe geç
HP Pavilion 11 x360 Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion 11 x360 Keyboard Replacement, Remove Screws: adım 1, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Remove Screws: adım 1, 2 resimden 2.
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Keyboard Replacement, Remove Backing: adım 2, 3 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Remove Backing: adım 2, 3 resimden 2. HP Pavilion 11 x360 Keyboard Replacement, Remove Backing: adım 2, 3 resimden 3.
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Keyboard Replacement, Detach Cable: adım 3, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Detach Cable: adım 3, 2 resimden 2.
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Keyboard Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Keyboard Replacement: adım 5, 3 resimden 1. HP Pavilion 11 x360 Keyboard Replacement: adım 5, 3 resimden 2. HP Pavilion 11 x360 Keyboard Replacement: adım 5, 3 resimden 3.
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Keyboard Replacement: adım 6, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement: adım 6, 2 resimden 2.
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Keyboard Replacement: adım 7, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement: adım 7, 2 resimden 2.
    • Remove the battery.
  8. HP Pavilion 11 x360 Keyboard Replacement, Remove Screws: adım 8, 1 resimden 1.
    • Remove the two 3mm screws with the PH0 screwdriver.
  9. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Cable: adım 9, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Cable: adım 9, 2 resimden 2.
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
  10. HP Pavilion 11 x360 Keyboard Replacement, Remove Hard Drive: adım 10, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Remove Hard Drive: adım 10, 2 resimden 2.
    • Remove the three 3mm screws using the PH0 screwdriver.
    • Pull the hard drive slightly away from the connection to easily disconnect the hard drive cable from the motherboard.
    • Remove the hard drive.
  11. HP Pavilion 11 x360 Keyboard Replacement: adım 11, 1 resimden 1.
    • Remove the four 3mm screws using the PH0 screwdriver.
  12. HP Pavilion 11 x360 Keyboard Replacement: adım 12, 3 resimden 1. HP Pavilion 11 x360 Keyboard Replacement: adım 12, 3 resimden 2. HP Pavilion 11 x360 Keyboard Replacement: adım 12, 3 resimden 3.
    • Remove the two screws from the metal hinge on the power button side using the PH0 screwdriver.
    • One silver 4mm screw
    • One black 5mm screw
    • Lift up the hinge to remove the metal bracket underneath.
  13. HP Pavilion 11 x360 Keyboard Replacement: adım 13, 3 resimden 1. HP Pavilion 11 x360 Keyboard Replacement: adım 13, 3 resimden 2. HP Pavilion 11 x360 Keyboard Replacement: adım 13, 3 resimden 3.
    • Remove one 3mm screw using the PH0 screwdriver from the metal hinge located on the power connector side of the computer.
    • Lift up the hinge with some force to remove the metal bracket underneath.
  14. HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Wireless Card: adım 14, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Wireless Card: adım 14, 2 resimden 2.
    • Unscrew the two 3mm screws with the PH0 screwdriver.
    • Pull the wireless card out of its port to disconnect it from the motherboard.
  15. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Keyboard Cable: adım 15, 3 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Keyboard Cable: adım 15, 3 resimden 2. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Keyboard Cable: adım 15, 3 resimden 3.
    • Push the black tab away from the hinge of the laptop.
    • After the black tab has been flipped, pull out the blue cable to disconnect the keyboard cable.
  16. HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Webcam Cable: adım 16, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Webcam Cable: adım 16, 2 resimden 2.
    • Pull horizontally toward the hinge of the laptop to disconnect the webcam cable.
  17. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Display Cable: adım 17, 3 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Display Cable: adım 17, 3 resimden 2. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Display Cable: adım 17, 3 resimden 3.
    • Pull up on the black tabs to disconnect the display cable.
  18. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Power Button Board: adım 18, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Power Button Board: adım 18, 2 resimden 2.
    • Pull the cable horizontally away from the motherboard to disconnect the power button board cable.
  19. HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Power Connector Cable: adım 19, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Disconnect the Power Connector Cable: adım 19, 2 resimden 2.
    • Pull the cable horizontally away from the motherboard to disconnect the power connector cable.
  20. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Speaker Cable: adım 20, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Disconnect Speaker Cable: adım 20, 2 resimden 2.
    • Pull the cable horizontally away from the motherboard to disconnect the speaker cable.
  21. HP Pavilion 11 x360 Keyboard Replacement, Remove Touch Pad Cable: adım 21, 3 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Remove Touch Pad Cable: adım 21, 3 resimden 2. HP Pavilion 11 x360 Keyboard Replacement, Remove Touch Pad Cable: adım 21, 3 resimden 3.
    • Push the white tab up toward the hinge of the laptop.
    • Disconnect touch pad cable by pulling up and away from the motherboard.
  22. HP Pavilion 11 x360 Keyboard Replacement: adım 22, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement: adım 22, 2 resimden 2.
    • Lift up to remove the motherboard.
  23. HP Pavilion 11 x360 Keyboard Replacement: adım 23, 3 resimden 1. HP Pavilion 11 x360 Keyboard Replacement: adım 23, 3 resimden 2. HP Pavilion 11 x360 Keyboard Replacement: adım 23, 3 resimden 3.
    • Push outwards on the two black tabs to pop the RAM up.
  24. HP Pavilion 11 x360 Keyboard Replacement: adım 24, 1 resimden 1.
    • Remove the RAM.
  25. HP Pavilion 11 x360 Keyboard Replacement: adım 25, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement: adım 25, 2 resimden 2.
    • Lift up the heat sink to remove it from the motherboard.
  26. HP Pavilion 11 x360 Keyboard Replacement, Detach Keyboard: adım 26, 2 resimden 1. HP Pavilion 11 x360 Keyboard Replacement, Detach Keyboard: adım 26, 2 resimden 2.
    • Remove the fifteen 3mm screws connected directly to the keyboard using the PH0 screwdriver.
    • Remove the 3mm screw under the keyboard cable using the PH0 screwdriver.
  27. HP Pavilion 11 x360 Keyboard Replacement, Remove Power Button Board: adım 27, 1 resimden 1.
    • Remove the two 3mm screws attached to the power button board.
    • Lift out power button board.
  28. HP Pavilion 11 x360 Keyboard Replacement: adım 28, 3 resimden 1. HP Pavilion 11 x360 Keyboard Replacement: adım 28, 3 resimden 2. HP Pavilion 11 x360 Keyboard Replacement: adım 28, 3 resimden 3.
    • Lift keyboard out.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Natalie
937 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-9, Maness Winter 2015 Cal Poly, Team 19-9, Maness Winter 2015 üyesi
CPSU-MANESS-W15S19G9
4 Üyeler
12 adet Kılavuz yazıldı
3 Yorum
Best guide. I just ordered keypad for my laptop. Thank you very much for sharing this!
ashumicro - Yanıt
I just replaced my keyboard and everything was exactly like the guide. Worked perfectly.
Robert Young - Yanıt
Hello, I'm the computer tech for a school, we have about 500 HP Probook x360 11 G1 EE, and often the key pop out and the hinge are broken, not the key. Where can I buy a bunch (like 25+) of hinges only.
XAVIER FRETARD - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 13,420
