Ana içeriğe geç
HP Pavilion 11 x360 Speakers Replacement
Neye ihtiyacın var
  1. HP Pavilion 11 x360 Speakers Replacement, Remove Screws: adım 1, 2 resimden 1. HP Pavilion 11 x360 Speakers Replacement, Remove Screws: adım 1, 2 resimden 2.
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Speakers Replacement, Remove Backing: adım 2, 3 resimden 1. HP Pavilion 11 x360 Speakers Replacement, Remove Backing: adım 2, 3 resimden 2. HP Pavilion 11 x360 Speakers Replacement, Remove Backing: adım 2, 3 resimden 3.
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Speakers Replacement, Detach Cable: adım 3, 2 resimden 1. HP Pavilion 11 x360 Speakers Replacement, Detach Cable: adım 3, 2 resimden 2.
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Speakers Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Speakers Replacement: adım 5, 3 resimden 1. HP Pavilion 11 x360 Speakers Replacement: adım 5, 3 resimden 2. HP Pavilion 11 x360 Speakers Replacement: adım 5, 3 resimden 3.
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Speakers Replacement: adım 6, 2 resimden 1. HP Pavilion 11 x360 Speakers Replacement: adım 6, 2 resimden 2.
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Speakers Replacement: adım 7, 2 resimden 1. HP Pavilion 11 x360 Speakers Replacement: adım 7, 2 resimden 2.
    • Remove the battery.
  8. HP Pavilion 11 x360 Speakers Replacement, Speakers: adım 8, 3 resimden 1. HP Pavilion 11 x360 Speakers Replacement, Speakers: adım 8, 3 resimden 2. HP Pavilion 11 x360 Speakers Replacement, Speakers: adım 8, 3 resimden 3.
    • Remove two 6mm screws on each speaker with the PH0 screwdriver.
  9. HP Pavilion 11 x360 Speakers Replacement: adım 9, 3 resimden 1. HP Pavilion 11 x360 Speakers Replacement: adım 9, 3 resimden 2. HP Pavilion 11 x360 Speakers Replacement: adım 9, 3 resimden 3.
    • Disconnect the black cable that attaches the speakers to the motherboard by gently pulling the cable outward.
    • Remove the speakers.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Natalie
937 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-9, Maness Winter 2015 Cal Poly, Team 19-9, Maness Winter 2015 üyesi
CPSU-MANESS-W15S19G9
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,616
