Ana içeriğe geç
HP Pavilion 11-n010dx Ram Replacement
Neye ihtiyacın var
  1. HP Pavilion 11-n010dx Ram Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 11-n010dx Ram Replacement, Battery: adım 1, 2 resimden 2.
    • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
    • Use the Phillips #0 to remove four 9mm screws.
    • Use the Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Ram Replacement: adım 2, 3 resimden 1. HP Pavilion 11-n010dx Ram Replacement: adım 2, 3 resimden 2. HP Pavilion 11-n010dx Ram Replacement: adım 2, 3 resimden 3.
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Ram Replacement: adım 3, 2 resimden 1. HP Pavilion 11-n010dx Ram Replacement: adım 3, 2 resimden 2.
    • Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
  4. HP Pavilion 11-n010dx Ram Replacement: adım 4, 1 resimden 1.
    • Remove the five 6mm screws that hold the battery in place using the Phillips #0.
  5. HP Pavilion 11-n010dx Ram Replacement: adım 5, 2 resimden 1. HP Pavilion 11-n010dx Ram Replacement: adım 5, 2 resimden 2.
    • Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
  6. HP Pavilion 11-n010dx Ram Replacement: adım 6, 2 resimden 1. HP Pavilion 11-n010dx Ram Replacement: adım 6, 2 resimden 2.
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  7. HP Pavilion 11-n010dx Ram Replacement: adım 7, 1 resimden 1.
    • Remove the battery from your device.
  8. HP Pavilion 11-n010dx Ram Replacement, Ram: adım 8, 2 resimden 1. HP Pavilion 11-n010dx Ram Replacement, Ram: adım 8, 2 resimden 2.
    • Using your fingernails, pull the tabs on either side of the RAM to release the module from its secured spot.
  9. HP Pavilion 11-n010dx Ram Replacement: adım 9, 2 resimden 1. HP Pavilion 11-n010dx Ram Replacement: adım 9, 2 resimden 2.
    • Carefully grab and pull to remove the RAM from your device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joseph Lintz
915 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-5, Blackwell Fall 2016 USF Tampa, Team 11-5, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S11G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 718
