Ana içeriğe geç
HP Pavilion 13-s128nr Back Panel Replacement
Neye ihtiyacın var
  1. HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: adım 1, 2 resimden 1. HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: adım 1, 2 resimden 2.
    • Use the iFixit opening tool to take off the rubber caps.
    • Remove the screws using the Phillips #0 screwdriver.
  2. HP Pavilion 13-s128nr Back Panel Replacement: adım 2, 1 resimden 1.
    • Use the Jimmy to pry around the seam of the laptop.
    • Remove the back panel of the laptop.
    • Don't completely remove the back panel as there are ribbon cables that can be easily damaged if removed quickly.
  3. HP Pavilion 13-s128nr Back Panel Replacement: adım 3, 2 resimden 1. HP Pavilion 13-s128nr Back Panel Replacement: adım 3, 2 resimden 2.
    • Using the iFixit opening tool to lift the tabs holding in the cables connecting the keyboard to the motherboard.
    • Pull the cable from the motherboard.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 15
Her zaman: 791
