Ana içeriğe geç
HP Pavilion 14-b015dx Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-b015dx Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the computer is completely powered down and unplug the power cord.
  2. HP Pavilion 14-b015dx Hard Drive Replacement: adım 2, 1 resimden 1.
    • Place the device on your work surface with bottom facing up and the battery located at the top.
  3. HP Pavilion 14-b015dx Hard Drive Replacement: adım 3, 1 resimden 1.
    • Slide the left release tab toward the center of the computer to the unlock position. Next slid the right tab toward the center of the computer and hold it there while completing step 4.
  4. HP Pavilion 14-b015dx Hard Drive Replacement: adım 4, 1 resimden 1.
    • Remove the battery by sliding it upwards and away from the computer.
  5. HP Pavilion 14-b015dx Hard Drive Replacement, Keyboard: adım 5, 1 resimden 1.
    • Unscrew the ten 6.0 mm Philips head screws on the base of the device with a Phillips #0 head screwdriver.
  6. HP Pavilion 14-b015dx Hard Drive Replacement: adım 6, 1 resimden 1.
    • Insert the plastic opening tool between the keyboard and the plastic housing.
    • Pry the keyboard upward away from the device.
    • Move the tool around the edge of the entire keyboard while continuing to pry.
    • You will hear the clips pop once you have released them.
  7. HP Pavilion 14-b015dx Hard Drive Replacement: adım 7, 1 resimden 1.
    • Once you have released all of the clips, slowly lift the keyboard exposing the ribbon cable.
    • Lift the tab on the keyboard ZIF connector with a plastic opening tool and gently remove the ribbon cable.
  8. HP Pavilion 14-b015dx Hard Drive Replacement, Palm Rest: adım 8, 1 resimden 1.
    • Remove the eight 6.0 mm screws located under the keyboard with your Philips #0 screwdriver.
  9. HP Pavilion 14-b015dx Hard Drive Replacement: adım 9, 1 resimden 1.
    • Remove the track pad and power button ribbon cables.
    • Lift the locking bar on each connector with a plastic opening tool and gently remove the ribbon cables
  10. HP Pavilion 14-b015dx Hard Drive Replacement: adım 10, 1 resimden 1.
    • To remove the palm rest, insert the plastic opening tool in the seam between the palm rest and the base.
    • Pry upward to undo each clip.
    • Continue this process around the entire palm rest.
  11. HP Pavilion 14-b015dx Hard Drive Replacement: adım 11, 1 resimden 1.
    • Once all clips have been undone lift the palm rest away from the laptop.
  12. HP Pavilion 14-b015dx Hard Drive Replacement, Hard Drive: adım 12, 1 resimden 1.
    • Gently unhook the ribbon cable blocking the hard drive by lifting the locking bar with a plastic opening tool.
  13. HP Pavilion 14-b015dx Hard Drive Replacement: adım 13, 1 resimden 1.
    • Remove the 2 screws securing the hard drive
    • Lift the hard drive up and remove the connector on the end using the blue opening tool.
Sonuç
Gregory Bridge
623 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 üyesi
UMASSD-ISAACSON-F17S1G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 2,189
