Ana içeriğe geç
HP Pavilion 14-b015dx Wireless Card Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-b015dx Wireless Card Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the computer is completely powered down and unplug the power cord.
  2. HP Pavilion 14-b015dx Wireless Card Replacement: adım 2, 1 resimden 1.
    • Place the device on your work surface with bottom facing up and the battery located at the top.
  3. HP Pavilion 14-b015dx Wireless Card Replacement: adım 3, 1 resimden 1.
    • Slide the left release tab toward the center of the computer to the unlock position. Next slid the right tab toward the center of the computer and hold it there while completing step 4.
  4. HP Pavilion 14-b015dx Wireless Card Replacement: adım 4, 1 resimden 1.
    • Remove the battery by sliding it upwards and away from the computer.
  5. HP Pavilion 14-b015dx Wireless Card Replacement, Keyboard: adım 5, 1 resimden 1.
    • Unscrew the ten 6.0 mm Philips head screws on the base of the device with a Phillips #0 head screwdriver.
  6. HP Pavilion 14-b015dx Wireless Card Replacement: adım 6, 1 resimden 1.
    • Insert the plastic opening tool between the keyboard and the plastic housing.
    • Pry the keyboard upward away from the device.
    • Move the tool around the edge of the entire keyboard while continuing to pry.
    • You will hear the clips pop once you have released them.
  7. HP Pavilion 14-b015dx Wireless Card Replacement: adım 7, 1 resimden 1.
    • Once you have released all of the clips, slowly lift the keyboard exposing the ribbon cable.
    • Lift the tab on the keyboard ZIF connector with a plastic opening tool and gently remove the ribbon cable.
  8. HP Pavilion 14-b015dx Wireless Card Replacement, Palm Rest: adım 8, 1 resimden 1.
    • Remove the eight 6.0 mm screws located under the keyboard with your Philips #0 screwdriver.
  9. HP Pavilion 14-b015dx Wireless Card Replacement: adım 9, 1 resimden 1.
    • Remove the track pad and power button ribbon cables.
    • Lift the locking bar on each connector with a plastic opening tool and gently remove the ribbon cables
  10. HP Pavilion 14-b015dx Wireless Card Replacement: adım 10, 1 resimden 1.
    • To remove the palm rest, insert the plastic opening tool in the seam between the palm rest and the base.
    • Pry upward to undo each clip.
    • Continue this process around the entire palm rest.
  11. HP Pavilion 14-b015dx Wireless Card Replacement: adım 11, 1 resimden 1.
    • Once all clips have been undone lift the palm rest away from the laptop.
  12. HP Pavilion 14-b015dx Wireless Card Replacement, Wireless Card: adım 12, 1 resimden 1.
    • Remove the two 4.0 mm long screws on the corners of the wireless card the using a Philips #0 screwdriver.
  13. HP Pavilion 14-b015dx Wireless Card Replacement: adım 13, 1 resimden 1.
    • Remove the black and white wires attached to the wireless card by using your blue opening tool and prying upward.
  14. HP Pavilion 14-b015dx Wireless Card Replacement: adım 14, 1 resimden 1.
    • Once you have removed the screws and wires on the network card lift it up and away from the motherboard.
Sonuç
Gregory Bridge
623 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 üyesi
UMASSD-ISAACSON-F17S1G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 320
