Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide will walk you through replacing the audio port and USB drive card using an iFixit PH0 screwdriver and plastic opening tool.
Parçalar
Hiçbir parça belirtilmedi.
  1. Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. Flip the laptop upside down so that the bottom is facing you. Push the slide on the right toward the center of the laptop, releasing the battery latch. Lift the battery up and away from the laptop.
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. Insert the plastic opening tool between the keyboard and the palm rest. Pry upwards until the keyboard section detaches from the laptop. Repeat this around the edge of the entire keyboard.
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. Lift the  keyboard slowly up until the connecting cable is exposed. Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
  5. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver. Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
    • Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
  7. Insert the plastic opening tool into the seam between the palm rest and the laptop. Pry upwards until the palm rest separates from the laptop. Repeat this process around the entire computer.
    • Insert the plastic opening tool into the seam between the palm rest and the laptop.
    • Pry upwards until the palm rest separates from the laptop.
    • Repeat this process around the entire computer.
    • These steps will be similar to the ones you took to remove the keyboard. Again, you will hear snapping noises.
  8. Lift upwards to remove the palm rest.
    • Lift upwards to remove the palm rest.
  9. Carefully disconnect the cable connecting the ports to the motherboard from the right side. Carefully disconnect the cable connecting the ports to the motherboard from the right side.
    • Carefully disconnect the cable connecting the ports to the motherboard from the right side.
  10. Remove the two 6.0 mm screws from the ports. Remove the two 6.0 mm screws from the ports. Remove the two 6.0 mm screws from the ports.
    • Remove the two 6.0 mm screws from the ports.
  11. Push the ports to the left and lift upward to remove them safely. Push the ports to the left and lift upward to remove them safely.
    • Push the ports to the left and lift upward to remove them safely.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Erin Lavalla
458 İtibar
4 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 4-4, Catania Fall 2016 UMass Dartmouth, Team 4-4, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G4
3 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
where can I find the replacement part?
edwin abraham - Yanıt
Hello, first I just wanted to say thank you so much for writing these guides! You’re a super hero…. now then, I find myself in quite a pickle. I have an HP 15-b123cl with a screen that’s broken. I need to resolder one of the connectors. I have a picture that will show you which connector I need to fix, but I can’t post a picture in this comment section… all I need is a picture of the display connector on the top left of the motherboard. I even checked ifixit for some way of messaging you directly, but no luck :(… all I can think to do is give you my personal email address and hope that you send me something! Anyways… THANKS ERIN
Ethan
ejstepanianATgmail.com
Ethan Stepanian - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 496
