Ana içeriğe geç
Giriş
In this guide, the main objective is to remove the battery from the computer.
  1. Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. Flip the laptop upside down so that the bottom is facing you. Push the slide on the right toward the center of the laptop, releasing the battery latch. Lift the battery up and away from the laptop.
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Erin Lavalla
458 İtibar
4 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 4-4, Catania Fall 2016 UMass Dartmouth, Team 4-4, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 430
