Ana içeriğe geç
HP Pavilion 14-b120dx CPU Cooling Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: adım 2, 3 resimden 1. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: adım 2, 3 resimden 2. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: adım 2, 3 resimden 3.
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Keyboard: adım 3, 3 resimden 1. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Keyboard: adım 3, 3 resimden 2. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Keyboard: adım 3, 3 resimden 3.
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: adım 4, 2 resimden 1. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
  5. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Palm Rest: adım 5, 2 resimden 1. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, Palm Rest: adım 5, 2 resimden 2.
    • Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
  6. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: adım 6, 3 resimden 1. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: adım 6, 3 resimden 2. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: adım 6, 3 resimden 3.
    • Insert the plastic opening tool into the seam between the palm rest and the laptop.
    • Pry upwards until the palm rest separates from the laptop.
    • Repeat this process around the entire computer.
    • These steps will be similar to the ones you took to remove the keyboard. Again, you will hear snapping noises.
  7. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: adım 7, 1 resimden 1.
    • Lift upwards to remove the palm rest.
  8. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, CPU Cooling Fan: adım 8, 2 resimden 1. HP Pavilion 14-b120dx CPU Cooling Fan Replacement, CPU Cooling Fan: adım 8, 2 resimden 2.
    • Locate the fan in the upper left hand corner of the laptop.
    • Remove the cable connecting the fan to the motherboard.
    • Be sure not to damage the motherboard or the connecting cable. Carefully apply force to remove the cable.
  9. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: adım 9, 2 resimden 1. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: adım 9, 2 resimden 2.
    • Unscrew the 3 6.0 mm screws holding the fan with a Phillips #0 head screwdriver.
  10. HP Pavilion 14-b120dx CPU Cooling Fan Replacement: adım 10, 1 resimden 1.
    • Remove the fan by pulling upward and to the right.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Erin Lavalla
458 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Catania Fall 2016 UMass Dartmouth, Team 4-4, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 1,252
