Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If you're experiencing frequent overheating, your fan may need replacing. Use this guide to replace your laptop's fan.
Neye ihtiyacın var
Insert the plastic opening tool between the keyboard and the palm rest.
Pry upwards until the keyboard section detaches from the laptop.
Repeat this around the edge of the entire keyboard.
Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
Locate the fan in the upper left hand corner of the laptop.
Remove the cable connecting the fan to the motherboard.
Bir başkası bu kılavuzu tamamladı.
