Ana içeriğe geç
HP Pavilion 14-bk061st Motherboard Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-bk061st Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. HP Pavilion 14-bk061st Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Motherboard Replacement: adım 2, 1 resimden 1.
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Motherboard Replacement: adım 3, 1 resimden 1.
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Motherboard Replacement, RAM Card: adım 4, 1 resimden 1.
    • Use the hook end of the Halberd spudger to pull back the clamps holding the card in place.
    • Take care when pulling the second clamp as the card has a tendency to jump out.
  5. HP Pavilion 14-bk061st Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the card by pulling it up and away from the slot.
  6. HP Pavilion 14-bk061st Motherboard Replacement, WLAN Card: adım 6, 2 resimden 1. HP Pavilion 14-bk061st Motherboard Replacement, WLAN Card: adım 6, 2 resimden 2.
    • Disconnect the two Wi-Fi and Bluetooth antenna wires by gently pulling them away from the board.
  7. HP Pavilion 14-bk061st Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the JIS #1 screw from the WLAN card.
  8. HP Pavilion 14-bk061st Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the card by pulling it away from the slot.
  9. HP Pavilion 14-bk061st Motherboard Replacement, Heat Sink: adım 9, 2 resimden 1. HP Pavilion 14-bk061st Motherboard Replacement, Heat Sink: adım 9, 2 resimden 2.
    • Remove the four 2.9mm JIS #1 screws from each of the four corners of the fan.
  10. HP Pavilion 14-bk061st Motherboard Replacement: adım 10, 1 resimden 1.
    • Carefully grab the heat sink from any side and lift straight up while trying to avoid touching other components.
    • Avoid bending the heat-pipe at all costs to keep it functional.
  11. HP Pavilion 14-bk061st Motherboard Replacement, Fan: adım 11, 1 resimden 1.
    • Remove the three 2.9mm JIS #1 screws surrounding the fan.
  12. HP Pavilion 14-bk061st Motherboard Replacement: adım 12, 2 resimden 1. HP Pavilion 14-bk061st Motherboard Replacement: adım 12, 2 resimden 2.
    • Carefully lift up the fan without tugging out the attached wire, and lay it on the motherboard.
    • Use tweezers to gently unplug the power connector wire.
    • Remove the fan from the laptop.
  13. HP Pavilion 14-bk061st Motherboard Replacement, Motherboard: adım 13, 1 resimden 1.
    • Remove the seven screws from the motherboard using a JIS #1 screwdriver.
  14. HP Pavilion 14-bk061st Motherboard Replacement: adım 14, 2 resimden 1. HP Pavilion 14-bk061st Motherboard Replacement: adım 14, 2 resimden 2.
    • Remove the nine cables from the motherboard by carefully lifting the black tab on each connector.
  15. HP Pavilion 14-bk061st Motherboard Replacement: adım 15, 1 resimden 1.
    • Carefully remove the motherboard from the casing.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mehrab Daemi
596 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 895
