Ana içeriğe geç
HP Pavilion 14-bk061st RAM Card Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-bk061st RAM Card Replacement, Back Panel: adım 1, 2 resimden 1. HP Pavilion 14-bk061st RAM Card Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st RAM Card Replacement: adım 2, 1 resimden 1.
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st RAM Card Replacement: adım 3, 1 resimden 1.
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st RAM Card Replacement, RAM Card: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Halberd Spudger
    $2.99
    • Use the hook end of the Halberd spudger to pull back the clamps holding the card in place.
    • Take care when pulling the second clamp as the card has a tendency to jump out.
  5. HP Pavilion 14-bk061st RAM Card Replacement: adım 5, 1 resimden 1.
    • Remove the card by pulling it up and away from the slot.
Sonuç
To reassemble your device, follow these instructions in reverse order. Make sure that that the card is fully inserted otherwise your computer may not work and the card may be damaged. If the card is not seated properly it may come out of its slot and hit other components inside the laptop when it is moved around.
3 farklı kişi bu kılavuzu tamamladı.
Sayyed Raza
154 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 451
