Ana içeriğe geç
HP Pavilion 14-bk061st Screen Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-bk061st Screen Replacement, Back Panel: adım 1, 2 resimden 1. HP Pavilion 14-bk061st Screen Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Screen Replacement: adım 2, 1 resimden 1.
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Screen Replacement: adım 3, 1 resimden 1.
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Screen Replacement, Screen: adım 4, 2 resimden 1. HP Pavilion 14-bk061st Screen Replacement, Screen: adım 4, 2 resimden 2.
    • Remove the five JIS #1 screws that attach the hinges of the screen to the casing of the laptop.
  5. HP Pavilion 14-bk061st Screen Replacement: adım 5, 2 resimden 1. HP Pavilion 14-bk061st Screen Replacement: adım 5, 2 resimden 2.
    • Carefully lift the hinges from the encasing and lift the bottom half of the laptop away from the screen.
  6. HP Pavilion 14-bk061st Screen Replacement: adım 6, 3 resimden 1. HP Pavilion 14-bk061st Screen Replacement: adım 6, 3 resimden 2. HP Pavilion 14-bk061st Screen Replacement: adım 6, 3 resimden 3.
    • Use the metal spudger to carefully pry off the plastic encasing around the monitor.
    • Use the outside of the screen to remove the plastic encasing to avoid damaging the screen itself.
  7. HP Pavilion 14-bk061st Screen Replacement: adım 7, 2 resimden 1. HP Pavilion 14-bk061st Screen Replacement: adım 7, 2 resimden 2.
    • Remove the four JIS #1 screws holding the screen in place.
  8. HP Pavilion 14-bk061st Screen Replacement: adım 8, 3 resimden 1. HP Pavilion 14-bk061st Screen Replacement: adım 8, 3 resimden 2. HP Pavilion 14-bk061st Screen Replacement: adım 8, 3 resimden 3.
    • Carefully remove the sticker covering the wire that connects the screen to the motherboard.
    • Disconnect the cable that is connected to the screen.
  9. HP Pavilion 14-bk061st Screen Replacement: adım 9, 1 resimden 1.
    • Remove the screen from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mehrab Daemi
596 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 854
