Ana içeriğe geç
HP Pavilion 14-c015dx Chromebook Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-c015dx Chromebook Fan Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
    • These screws may not completely come out of the laptop, so just make sure that you have loosened them all of the way.
  2. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 2, 2 resimden 1. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 2, 2 resimden 2.
    • Starting from the left side, use the metal spudger to pry off the keyboard.
    • Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
    • Do not pull the keyboard away from the computer while popping the keyboard off, there is a connector cable in the bottom center of the keyboard that will be disconnected in the next step.
  3. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 3, 3 resimden 1. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 3, 3 resimden 2. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 3, 3 resimden 3.
    • Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
    • Lift the keyboard away from the computer once the connector is detached.
  4. HP Pavilion 14-c015dx Chromebook Fan Replacement, Fan: adım 4, 2 resimden 1. HP Pavilion 14-c015dx Chromebook Fan Replacement, Fan: adım 4, 2 resimden 2.
    • Locate these seven circled screws.
    • Remove the seven 5mm screws using the Phillips Head #1 Screwdriver.
  5. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 5, 3 resimden 1. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 5, 3 resimden 2. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 5, 3 resimden 3.
    • Locate the ribbon cable near the top of the keyboard area.
    • At the cable base, lift the white tab with a fingernail and then pull on the blue section of the cable to release it.
  6. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 6, 3 resimden 1. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 6, 3 resimden 2. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 6, 3 resimden 3.
    • Locate the ribbon cable just above the touchpad.
    • Disconnect the cable by lifting the white tab at the base of the cable with a fingernail and then pulling on the blue section of the cable.
  7. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 7, 2 resimden 1. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 7, 2 resimden 2.
    • Remove the eight 7mm screws with a Philips Head #1 screwdriver.
  8. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 8, 1 resimden 1.
    • Remove the plastic palm rest assembly using the metal spudger.
    • Go little by little around the edge and carefully pry off the plastic palm rest assembly.
  9. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 9, 2 resimden 1. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 9, 2 resimden 2.
    • Locate the protective yellow tape that is covering two wires in between the fan and the motherboard.
    • Remove this yellow tape.
    • Some laptops may not have this protective yellow tape. If yours does not it does not matter, just skip this step.
  10. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 10, 2 resimden 1. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 10, 2 resimden 2.
    • Locate the single remaining screw holding the fan in place.
    • Remove the 5 mm screw using a Phillips Head #1 Screw Driver.
  11. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 11, 3 resimden 1. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 11, 3 resimden 2. HP Pavilion 14-c015dx Chromebook Fan Replacement: adım 11, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Locate the wires that connect the fan to the motherboard.
    • Remove this wire connector using the tweezers.
    • You can now completely remove the fan from the laptop.
Sonuç
William Busby
234 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-8, Maness Winter 2017 Cal Poly, Team 22-8, Maness Winter 2017 üyesi
CPSU-MANESS-W17S22G8
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 372
