Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
Starting from the left side, use the metal spudger to pry off the keyboard.
Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
Lift the keyboard away from the computer once the connector is detached.
Locate these seven 5mm circled screws on the panel that was under the keyboard.
Remove the screws with a Phillips Head #1 Screwdriver.
Locate the ribbon cable located at the top of the keyboard area.
At the cable base, lift the white tab with a fingernail and then gently pull on the blue tab of the cable to release it.
Locate the ribbon cable just above the touchpad.
Disconnect the cable by lifting the white tab at the base of the cable with a fingernail and then pulling on the blue section of the cable.
Locate these eight 7mm screws on the bottom of the laptop.
Remove using a Philips Head #1 Screwdriver.
Flip the computer back over, and using the metal spudger, remove the plastic palm rest assembly.
Go little by little around the edge and carefully pry off the plastic palm rest assembly.
Flip the plastic flap to unattach the metal strip located at the bottom left corner.
Remove the circled screw located at the bottom left using a Phillips #1 Screwdriver.
You can now disconnect the headphone jack piece.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
It would be great if somebody could help me with the issue I’m facing. My laptop is an HP Pavilion Sleekbook14b030tu, the headphone jack doesn’t work always I mean it does not detect my earphones or any earphones for that matter. I contacted HP and they told me a method to fix this, they claim that this is caused by a power surge so holding the power button and the mute switch for 20 seconds after shutting down should resolve the issue. It worked a few times but now its gone completely . Do I have to replace it or what do I do to fix it permanently ?
