Ana içeriğe geç
HP Pavilion 14-c015dx Chromebook Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-c015dx Chromebook Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
    • These screws may not completely come out of the laptop, so just make sure that you have loosened them all of the way.
  2. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: adım 2, 2 resimden 1. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: adım 2, 2 resimden 2.
    • Starting from the left side, use the metal spudger to pry off the keyboard.
    • Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
    • Do not pull the keyboard away from the computer while popping the keyboard off, there is a connector cable in the bottom center of the keyboard that will be disconnected in the next step.
  3. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: adım 3, 3 resimden 1. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: adım 3, 3 resimden 2. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: adım 3, 3 resimden 3.
    • Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
    • Lift the keyboard away from the computer once the connector is detached.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joe Kennedy
231 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-8, Maness Winter 2017 Cal Poly, Team 22-8, Maness Winter 2017 üyesi
CPSU-MANESS-W17S22G8
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 445
