Ana içeriğe geç
HP Pavilion 14-cf0014dx RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-cf0014dx RAM Replacement, Back Panel: adım 1, 1 resimden 1.
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx RAM Replacement: adım 2, 1 resimden 1.
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx RAM Replacement, Battery: adım 3, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx RAM Replacement: adım 4, 1 resimden 1.
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx RAM Replacement, RAM: adım 5, 3 resimden 1. HP Pavilion 14-cf0014dx RAM Replacement, RAM: adım 5, 3 resimden 2. HP Pavilion 14-cf0014dx RAM Replacement, RAM: adım 5, 3 resimden 3.
    • Using your fingers, simultaneously press the two silver clamps away from each other to release the RAM.
    • Each RAM stick will pop up at a 45 degree angle.
    • Remove the RAM from the device.
Sonuç
Sam Cole
813 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G7
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 29
Her zaman: 588
