Ana içeriğe geç
HP Pavilion 14-cf0014dx SSD Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-cf0014dx SSD Replacement, Back Panel: adım 1, 1 resimden 1.
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx SSD Replacement: adım 2, 1 resimden 1.
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx SSD Replacement, Battery: adım 3, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx SSD Replacement: adım 4, 1 resimden 1.
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx SSD Replacement, SSD: adım 5, 2 resimden 1. HP Pavilion 14-cf0014dx SSD Replacement, SSD: adım 5, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the single screw securing the SSD to the motherboard.
  6. HP Pavilion 14-cf0014dx SSD Replacement: adım 6, 2 resimden 1. HP Pavilion 14-cf0014dx SSD Replacement: adım 6, 2 resimden 2.
    • Carefully pull the SSD out of the slot.
Sonuç
Sam Cole
813 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G7
3 Üyeler
Bir Yorum
Hola!, ¿cómo es el cable para el SSD (Hard drive cable L23187-001), así como su case? (Hard drive cover L23219-001) La imagen que me aparece en la red del cable es muy largo. Gracias.
Ernesto P Mitre M - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 598
