Ana içeriğe geç
HP Pavilion 14-n018us Display Assembly Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-n018us Display Assembly Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 14-n018us Display Assembly Replacement, Battery: adım 1, 2 resimden 2.
    • Prior to removing the base plate, the battery must be removed.
    • Press the two tabs on the back of the laptop inward to release the battery.
    • Pull the battery straight out slowly and firmly.
  2. HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: adım 2, 3 resimden 1. HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: adım 2, 3 resimden 2. HP Pavilion 14-n018us Display Assembly Replacement, Display Assembly: adım 2, 3 resimden 3.
    • Insert a plastic spudger into the groove around the laptop screen and gently loosen the plastic bezel away from the display.
    • Use the plastic spudger and loosen the display away from the back of the screen.
    • Continue to use the spudger to detach the small plastic detents holding the screen in place.
    • Disconnect the display cable and remove the screen.
  3. HP Pavilion 14-n018us Display Assembly Replacement: adım 3, 1 resimden 1.
    • The screen can now be reassembled!
Sonuç
Michael Hollister
253 İtibar
3 adet Kılavuz yazıldı
Ekip
Casper College, Team 1-1, Lareau Fall 2021 Casper College, Team 1-1, Lareau Fall 2021 üyesi
CASC-LAREAU-F21S1G1
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 210
