Ana içeriğe geç
HP Pavilion 14-n018us RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-n018us RAM Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 14-n018us RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Prior to removing the base plate, the battery must be removed.
    • Press the two tabs on the back of the laptop inward to release the battery.
    • Pull the battery straight out slowly and firmly.
  2. HP Pavilion 14-n018us RAM Replacement, Memory Module: adım 2, 2 resimden 1. HP Pavilion 14-n018us RAM Replacement, Memory Module: adım 2, 2 resimden 2.
    • Using a Phillips #00 screwdriver, unscrew the two 6.98 mm captive screws on the black cover on the bottom of the laptop.
    • Remove the cover.
  3. HP Pavilion 14-n018us RAM Replacement: adım 3, 3 resimden 1. HP Pavilion 14-n018us RAM Replacement: adım 3, 3 resimden 2. HP Pavilion 14-n018us RAM Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Push outwards on the two retaining clips on either side of each RAM chip to release the chips.
    • Use a pair of ESD-safe tweezers to gently slide the two memory modules out from the assembly.
    • If you don't have a suitable pair of tweezers, it's okay to use your fingers to remove the RAM chips. Just be sure to handle the chips by their edges, as skin contact on the faces of the chips can damage them.
Sonuç
Michael Hollister
253 İtibar
3 adet Kılavuz yazıldı
Ekip
Casper College, Team 1-1, Lareau Fall 2021 Casper College, Team 1-1, Lareau Fall 2021 üyesi
CASC-LAREAU-F21S1G1
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 144
