Ana içeriğe geç
HP Pavilion 14-q020nr Screen Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-q020nr Screen Replacement, Screen: adım 1, 1 resimden 1.
    • With the laptop facing you, open the clamshell. Be sure to turn the power off using a long press before beginning.
    • Remove the screw covers on both sides of the screen bezel by sliding a metal spudger into the crevice and gently peeling the cover away.
    • If the laptop turns on at any point during the repair, quickly turn it off with a long press
  2. HP Pavilion 14-q020nr Screen Replacement: adım 2, 1 resimden 1.
    • Remove both 4mm screws using a Phillips Head 1 screwdriver
  3. HP Pavilion 14-q020nr Screen Replacement: adım 3, 3 resimden 1. HP Pavilion 14-q020nr Screen Replacement: adım 3, 3 resimden 2. HP Pavilion 14-q020nr Screen Replacement: adım 3, 3 resimden 3.
    • Snap off the screen bezel by prying with your fingers in between the bezel and the screen.
    • Continue around the screen, gently prying and lifting.
    • You will hear a series of audible clicks as the bezel disconnects from the other hardware.
  4. HP Pavilion 14-q020nr Screen Replacement: adım 4, 1 resimden 1.
    • Carefully loosen the bottom bezel. Eventually it will snap free from the rest of the clamshell.
    • Pull hinge up and forward to detach it from the Chromebook. The bezel and hinge cover will remain attached.
  5. HP Pavilion 14-q020nr Screen Replacement: adım 5, 2 resimden 1. HP Pavilion 14-q020nr Screen Replacement: adım 5, 2 resimden 2.
    • Remove the four 4mm screws within the metal tabs on the top and bottom of the screen using a Phillips Head 1 screwdriver.
  6. HP Pavilion 14-q020nr Screen Replacement: adım 6, 3 resimden 1. HP Pavilion 14-q020nr Screen Replacement: adım 6, 3 resimden 2. HP Pavilion 14-q020nr Screen Replacement: adım 6, 3 resimden 3.
    • Gently pry the metal tabs off of the screen assembly while holding the screen to unlock them.
    • Grab the screen by its unlocked tabs and tilt it down and away from the screen assembly, laying it down.
    • The new screen may scratch, to avoid this put a cloth down on the keyboard before laying down the screen.
  7. HP Pavilion 14-q020nr Screen Replacement: adım 7, 2 resimden 1. HP Pavilion 14-q020nr Screen Replacement: adım 7, 2 resimden 2.
    • Peel off the barcode sticker to reveal the screen connector plug.
  8. HP Pavilion 14-q020nr Screen Replacement: adım 8, 3 resimden 1. HP Pavilion 14-q020nr Screen Replacement: adım 8, 3 resimden 2. HP Pavilion 14-q020nr Screen Replacement: adım 8, 3 resimden 3.
    • Slide the connector out from its plug on the screen using your fingers to completely disconnect the screen.
    • Using your fingers, slide the connector out from its plug attached to the screen to completely disconnect the old screen panel
Sonuç
Jenell Chase
210 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G2, Bruce Fall 2017 CSU Fullerton, Team S2-G2, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G2
3 Üyeler
6 adet Kılavuz yazıldı
4 Yorum
Where did you find a replacement screen?
Grant McPherson - Yanıt
We are only showing how to replace the screen, we did not actually purchase a new screen for this guide.
Samantha Esqueda -
i have a multi layered line going down the middle of my screen how would i go about fixing something like that?
aaron kremer - Yanıt
Sorry, we are only knowledgeable on how to replace the screen, not on the issues.
Samantha Esqueda - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 462
