Ana içeriğe geç
HP Pavilion 14-v062us Fan Replacement
Neye ihtiyacın var
    1. HP Pavilion 14-v062us Fan Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 14-v062us Fan Replacement, Battery: adım 1, 2 resimden 2.
      • Power laptop off and make sure it is not plugged into charger
      • Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 14-v062us Fan Replacement: adım 2, 2 resimden 1. HP Pavilion 14-v062us Fan Replacement: adım 2, 2 resimden 2.
      • Lift the battery upwards and out from the laptop
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion 14-v062us Fan Replacement, Keyboard: adım 3, 3 resimden 1. HP Pavilion 14-v062us Fan Replacement, Keyboard: adım 3, 3 resimden 2. HP Pavilion 14-v062us Fan Replacement, Keyboard: adım 3, 3 resimden 3.
      • Remove rectangular rubber tops with a spudger
      • Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
      • Remove plastic edge covering with the blue plastic opening tool.
      • Remove two 4.63 mm PH#1 screws located under plastic edge covering.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 14-v062us Fan Replacement: adım 4, 2 resimden 1. HP Pavilion 14-v062us Fan Replacement: adım 4, 2 resimden 2.
      • Use Phillips screwdriver #1
      • Remove all nine 7.09 mm PH#1 screw black screws including small rectangular cover.
      • Remove the three 7.14 mm PH#1 screws.
      • Remove the one 7.09 mm PH#1 screw that will be underneath the small rectangular cover
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion 14-v062us Fan Replacement: adım 5, 2 resimden 1. HP Pavilion 14-v062us Fan Replacement: adım 5, 2 resimden 2.
      • Remove disc tray
      • Locate screw within computer that is inside of where the disc tray was
      • Using a Phillips #1 screwdriver, unscrew the screw
      • Set laptop down and open laptop so the keyboard is facing you
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion 14-v062us Fan Replacement: adım 6, 3 resimden 1. HP Pavilion 14-v062us Fan Replacement: adım 6, 3 resimden 2. HP Pavilion 14-v062us Fan Replacement: adım 6, 3 resimden 3.
      • Using a spudger or plastic opening tool, pry along siding of keyboard, where it connects to the rest of the laptop
      • Pry until you are able to lift entire face and keyboard
      • Only cables should be connecting it underneath
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion 14-v062us Fan Replacement: adım 7, 3 resimden 1. HP Pavilion 14-v062us Fan Replacement: adım 7, 3 resimden 2. HP Pavilion 14-v062us Fan Replacement: adım 7, 3 resimden 3.
      • Disconnect/ unplug cables using plastic opening tool.
      • Separate the keyboard panel from the laptop with your hands.
      • Turn around the laptop and lay it flat.
      FixBot'a Sor
      Yorum Ekle
    6. HP Pavilion 14-v062us Fan Replacement: adım 8, 2 resimden 1. HP Pavilion 14-v062us Fan Replacement: adım 8, 2 resimden 2.
      • Use a spudger to pry around the first layer of the silver panel until you are able to remove it
      • Only use a metal spudger as a last resort
      FixBot'a Sor
      Yorum Ekle
    7. HP Pavilion 14-v062us Fan Replacement: adım 9, 3 resimden 1. HP Pavilion 14-v062us Fan Replacement: adım 9, 3 resimden 2. HP Pavilion 14-v062us Fan Replacement: adım 9, 3 resimden 3.
      • Using a spudger tool, start prying around the second layer of the silver panel until you are able to remove it
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion 14-v062us Fan Replacement, Fan: adım 10, 3 resimden 1. HP Pavilion 14-v062us Fan Replacement, Fan: adım 10, 3 resimden 2. HP Pavilion 14-v062us Fan Replacement, Fan: adım 10, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove all 6 screws (5.65 mm) from the motherboard, using Phillips screwdriver J0
      • There will be a silver covering (in a z shape) that needs to be removed using black tweezers or a plastic opening tool
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 14-v062us Fan Replacement: adım 11, 1 resimden 1.
      • Remove the two 5.66mm screws from the motherboard using Phillips head screwdriver J0
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion 14-v062us Fan Replacement: adım 12, 2 resimden 1. HP Pavilion 14-v062us Fan Replacement: adım 12, 2 resimden 2.
      • Remove entire motherboard from the laptop
      • Turn over and remove the single 5.63mm screw using a Phillips head screwdriver J0.
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion 14-v062us Fan Replacement: adım 13, 2 resimden 1. HP Pavilion 14-v062us Fan Replacement: adım 13, 2 resimden 2.
      • Remove wiring with plastic opening tool
      • Remove fan
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 46
Her zaman: 2,012
