Ana içeriğe geç
HP Pavilion 15-p Optical drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: adım 1, 3 resimden 1. HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: adım 1, 3 resimden 2. HP Pavilion 15-p Optical drive Replacement, Prepare the laptop: adım 1, 3 resimden 3.
    • Shut the laptop down until it is hibernated or shut off. Do not remove power until both lights turn off.
  2. HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: adım 2, 3 resimden 1. HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: adım 2, 3 resimden 2. HP Pavilion 15-p Optical drive Replacement, Unlock the  battery: adım 2, 3 resimden 3.
    • Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
  3. HP Pavilion 15-p Optical drive Replacement, Remove the battery: adım 3, 2 resimden 1. HP Pavilion 15-p Optical drive Replacement, Remove the battery: adım 3, 2 resimden 2.
    • Remove the battery. Pull the battery forward and remove it from the laptop.
  4. HP Pavilion 15-p Optical drive Replacement, Remove the screw: adım 4, 3 resimden 1. HP Pavilion 15-p Optical drive Replacement, Remove the screw: adım 4, 3 resimden 2. HP Pavilion 15-p Optical drive Replacement, Remove the screw: adım 4, 3 resimden 3.
    • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once this screw is removed.
  5. HP Pavilion 15-p Optical drive Replacement, Remove the optical drive tab: adım 5, 2 resimden 1. HP Pavilion 15-p Optical drive Replacement, Remove the optical drive tab: adım 5, 2 resimden 2.
    • Remove the screws holding the optical drive bracket onto the drive. To do this, use a Phillips #0 screwdriver.
  6. HP Pavilion 15-p Optical drive Replacement, Faceplate removal: adım 6, 3 resimden 1. HP Pavilion 15-p Optical drive Replacement, Faceplate removal: adım 6, 3 resimden 2. HP Pavilion 15-p Optical drive Replacement, Faceplate removal: adım 6, 3 resimden 3.
    • Be careful not to break any clips. The faceplate will still be usable, but will be loose fitting.
    • To remove the faceplate, open the optical drive with a paper clip. Once the tray is released, use a flat tool to release the visible clip on the faceplate. Once done, the faceplate should come off.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nick
88.911 İtibar
49 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.541 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 65
Her zaman: 7,226
