Ana içeriğe geç
HP Pavilion 15-AB153NR Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion 15-AB153NR Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure computer is turned off and unplugged.
    • Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
  2. HP Pavilion 15-AB153NR Battery Replacement: adım 2, 2 resimden 1. HP Pavilion 15-AB153NR Battery Replacement: adım 2, 2 resimden 2.
    • Slide the battery release latch on the right with continuous force from right to left.
    • Once battery pops, you may release latch.
  3. HP Pavilion 15-AB153NR Battery Replacement: adım 3, 2 resimden 1. HP Pavilion 15-AB153NR Battery Replacement: adım 3, 2 resimden 2.
    • Grab the battery, rotating upwards and away from you. This will remove the battery.
Sonuç
Nicole Vachon
944 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G4, Simcock Spring 2019 UMass Dartmouth, Team S1-G4, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S1G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 36
Her zaman: 605
